Installing WINE to run Windows Apps
13 Feb 2024 10:36 #293214
by Anthony H
Installing WINE to run Windows Apps was created by Anthony H
Has anyone successfully installed WINE to run windows apps on release 2.9.2 Bookworm release from the main site. Installs sucessfully using the graphical package manager, when I come to run says 32 bit components are missing.
As a background I have a very old LinuxCNC system that used to work doing this but the motherboard failed hence this step of building a new machine. The old system was built for me, I have retained the old hard drive. It is to use Vcarve on the same system.
Thanks.
Thanks.
- Thank you received: 5934
13 Feb 2024 13:07 #293221
Replied by tommylight on topic Installing WINE to run Windows Apps
Might have more luck on Debian forums, try searching there.
You can also try
sudo apt install mono
Then run it from the forlder where VCarve is located
mono vcarve
Old versions did work with this.
You can also try
mono vcarve
13 Feb 2024 18:11 #293245
by chris@cnc
Replied by chris@cnc on topic Installing WINE to run Windows Apps
I had the same problem. Installing wine could you find here. You have to enable i386 support for that old system.
wiki.winehq.org/Debian
16 Feb 2024 15:57 - 16 Feb 2024 15:59 #293513
by Anthony H
Replied by Anthony H on topic Installing WINE to run Windows Apps
chris@cnc
Thanks, the information in that link worked, once I'd got the system stable.
Last edit: 16 Feb 2024 15:59 by Anthony H. Reason: update
Time to create page: 0.163 seconds
