Error on atp upgrade
03 Mar 2024 15:18 #295057
by tommy
Error on atp upgrade was created by tommy
I have installed Linuxcnc from ISO (linuxcnc_2.9.1-amd64.hybrid.iso), few months ago, lately I see error on following components:
linux-image-6.1.0-18-rt-amd64
linux-image-rt-amd64
initramfs-tools
initramfs-tools
$ sudo apt upgrade
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
linux-headers-6.1.0-13-common-rt linux-headers-6.1.0-13-rt-amd64
linux-image-6.1.0-13-rt-amd64
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
4 not fully installed or removed.
Need to get 68.7 MB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://security.debian.org/debian-security bookworm-security/main amd64 linux-image-6.1.0-17-rt-amd64 amd64 6.1.69-1 [68.7 MB]
Fetched 68.7 MB in 7s (9,735 kB/s)
Setting up initramfs-tools (0.142) ...
update-initramfs: deferring update (trigger activated)
Setting up linux-image-6.1.0-18-rt-amd64 (6.1.76-1) ...
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.0-18-rt-amd64.
dkms: autoinstall for kernel: 6.1.0-18-rt-amd64.
/etc/kernel/postinst.d/dracut:
dracut: Generating /boot/initrd.img-6.1.0-18-rt-amd64
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-6.1.0-18-rt-amd64
raspi-firmware: missing /boot/firmware, did you forget to mount it?
run-parts: /etc/initramfs/post-update.d//z50-raspi-firmware exited with return c
ode 1
run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1
dpkg: error processing package linux-image-6.1.0-18-rt-amd64 (--configure):
installed linux-image-6.1.0-18-rt-amd64 package post-installation script subpro
cess returned error exit status 1
dpkg: dependency problems prevent configuration of linux-image-rt-amd64:
linux-image-rt-amd64 depends on linux-image-6.1.0-18-rt-amd64 (= 6.1.76-1); how
ever:
Package linux-image-6.1.0-18-rt-amd64 is not configured yet.
dpkg: error processing package linux-image-rt-amd64 (--configure):
dependency problems - leaving unconfigured
Processing triggers for initramfs-tools (0.142) ...
ode 1
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned
error exit status 1
Errors were encountered while processing:
initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
03 Mar 2024 15:21 #295058
by chris@cnc
Replied by chris@cnc on topic Error on atp upgrade
Time to create page: 0.317 seconds
