Unexpected realtime delay on task 0 on a HP8300
08 Mar 2024 03:22 #295436
by lrak
Unexpected realtime delay on task 0 on a HP8300 was created by lrak
This started after updating to debian bookworm(12) I started getting these errors - can take a week or two of uptime.
First question - it task 0 the Linux task number or something from linuxCNC?
I've seen conflicting advise about kernel command line settings:
PCW wrote:
"Unless you have an actual latency issue I would not use any isolcpus
options at all"
vs linuxcnc.org/docs/html/install/latency-test.html
Not sure I really have a latency issue - could be some cron-job of systemd-timer job is getting fired off.
Right now I've turned off a couple of apt-timer jobs in systemd - need to wait for an error.
options at all"
08 Mar 2024 04:09 #295437
Replied by PCW on topic Unexpected realtime delay on task 0 on a HP8300
1. What is you servo thread period?
2. Do you have AMT disabled in the BIOS?
3. Do you have IRQ coalescing disabled? (man hm2_eth)
The following user(s) said Thank You: lrak
08 Mar 2024 06:12 - 08 Mar 2024 06:14 #295439
by lrak
Replied by lrak on topic Unexpected realtime delay on task 0 on a HP8300
@PCW
1- in ~/linuxcnc/configs/machine.ini I have
SERVO_PERIOD = 1000000
2 - grub command line:
GRUB_CMDLINE_LINUX_DEFAULT="quiet text isolcpus=2,3 apparmor=0 apm=off"
3 - I have in /etc/network/interfaces a line commented out
# hardware−irq−coalesce−rx−usecs 0
What ever is happening is rare - never happened while the machine was cutting.
Last edit: 08 Mar 2024 06:14 by lrak.
08 Mar 2024 12:37 #295450
This should not be commented out
AMT is something that must be disabled in the BIOS,
not something that can be changed in the kernel/grub
- Thank you received: 5938
08 Mar 2024 14:33 #295459
Replied by tommylight on topic Unexpected realtime delay on task 0 on a HP8300
Also while in BIOS, disable hyperthreading.
08 Mar 2024 21:57 - 08 Mar 2024 22:48 #295479
by lrak
I left things running overnight - got the same error - no time stamp<grump>. (Is there a way to get a timestamp?).
Who or what is task-0 in the context of this error?
Trying enabling hardware−irq−coalesce−rx−usecs 0
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
auto eno1
allow-hotplug eno1
iface eno1 inet dhcp
#linuxCNC mesa interface
auto enp2s0
iface enp2s0 inet static
address 192.168.10.1/24
The mesa interface has a r8168 driver..
root@cnc:~# lspci |grep Ether
00:19.0 Ethernet controller: Intel Corporation 82579LM Gigabit Network Connection (Lewisville) (rev 04)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 07)
BIOS settings:
I do have AMT off
I also have all the power saving stuff turned off.
I do have:
Turbo mode - enabled
multi-processor - enabled
I found this in dmesg - I was thinking that the stock r8168 works now with bookworm? Do I still need to build a special one?
r8168: loading out-of-tree module taints kernel.
[ 1.396296] r8168: module verification failed: signature and/or required key missing - tainting kernel
[ 1.419277] ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20220331/utaddress-204)
[ 1.419282] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 1.419285] ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[ 1.419287] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 1.419287] ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[ 1.419289] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 1.419290] ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
[ 1.419292] ACPI: OSL: Resource conflict; ACPI support missing from driver?
[ 1.419292] lpc_ich: Resource conflict(s) found affecting gpio_ich
Latency test is showing after 10-min:
max servo jitter of 12104ns
max base thread of 7557ns
A bit OT:
Just checked - coreboot does not support the HP8300..
There was a industrial intel board that we used for digital-video back in the '90s that I know didn't have any hiccups other than thermal throttling of the MMU - which could be cured with the right heat-sink. Wish I still had one..
Such throttling still happens - some is independent of the management engines in the BIOSes .. Removing the thermal pads that go bad after a couple of years and replacing with good and proper heat-sink compound solves most of those problems. Video apps put a LOT of load on the MMUs - had to add the right heat-sink and fan.
auto lo
auto eno1
allow-hotplug eno1
auto enp2s0
BIOS settings:
I do have AMT off
I do have:
A bit OT:
Last edit: 08 Mar 2024 22:48 by lrak.
08 Mar 2024 22:03 #295481
Do you have an add-in Ethernet card?
because the built in Ethernet MAC on
a HP8300 is an Intel device not a Realtek
(at least the ones I have all have Intel MACs)
08 Mar 2024 22:50 #295482
by lrak
@PCW
Was editing my comment while you replied.
08 Mar 2024 23:49 #295483
Turbo mode should be off
Do you have an add-on network card?
10 Mar 2024 05:46 #295558
by lrak
@PCW who wrote "Do you have an add-on network card?"
Yes - The mesa interface is a realtek RTL8111/8168/8411 running via r8168 driver,
The onboard intel runs the LAN .
No error for 24hrs - restarting with turbo off.
Time to create page: 0.464 seconds
