DIY - MPG based on ESP32s2
15 Mar 2024 09:30 #295947
by meister
DIY - MPG based on ESP32s2 was created by meister
I have started to build an MPG,
based on an ESP32s2.
At the moment it is still connected via USB, but later it should run via WLAN and/or ESPnow
github.com/multigcs/linuxcnc-mpg
15 Mar 2024 14:08 #295963
by meister
Replied by meister on topic DIY - MPG based on ESP32s2
I am not yet sure how to assign the buttons:
1 Cycle Start
1a Cycle Stop
2 Feed Hold / Pause
3 Spindle On/Off
4 Flood On/Off
5 Set selected axis to zero (long press)
6 Scale 0.1 (long press: 1.0 ?)
6b Scale 0.01 (long press: 0.001 ?)
enc1 (toggle function ?)
enc2 (toggle function ?)
enc3 (toggle function ?)
does anyone have an idea ?
1 Cycle Start
1a Cycle Stop
2 Feed Hold / Pause
3 Spindle On/Off
4 Flood On/Off
The following user(s) said Thank You: zmrdko
15 Mar 2024 19:30 #295992
by meister
wireless
18 Mar 2024 12:28 #296189
by wez
Replied by wez on topic DIY - MPG based on ESP32s2
Nice work
18 Mar 2024 16:03 #296216
by zmrdko
Replied by zmrdko on topic DIY - MPG based on ESP32s2
I cant wait for wifi mode connection. Is it possible to make something like serial communication over wifi?
Will it be possible to connect more esp32 devices over wifi at once?
18 Mar 2024 16:09 #296219
by meister
do you mean wifi or esp_now ?
esp_now using wifi hardware but without the overhead, so it's more stable and faster,
no AP needed.
it is possible to connect multiple devices via wifi and via espnow,
but in this project, only one MPG is supported.
about 'normal' WIFI, i don't know if i support this in the future because espnow runs so so good and a 2. esp32 for the host-side costs not so much.
no AP needed.
18 Mar 2024 16:26 #296222
by zmrdko
so one ESP32 will be attached to LinuxCNC machine via USB (serial) like the master device and slave devices will communicate with master using espnow?
18 Mar 2024 17:34 #296232
by meister
exactly
19 Mar 2024 19:43 #296342
by meister
Multi-jogging on the Lathe:
Time to create page: 0.101 seconds
