odroid h4/h4+
27 Apr 2024 06:04 #299168
by vre
odroid h4/h4+ was created by vre
Has anyone tried odroid h4/h4+ ?
www.hardkernel.com/shop/odroid-h4
www.hardkernel.com/shop/odroid-h4-plus
latency-histogram ?
latency-histogram ?
27 Apr 2024 15:20 #299189
by cornholio
Replied by cornholio on topic odroid h4/h4+
H3+ is fine, that's what I use on my Mill. Cant' remember what the latency is, when using a Mesa motion control card it's not such an issue.
I'd take a very educated guess that the H4 wouldn't present any issues, Ethernet will be the only option for machine control.
You appear to be asking a lot of questions, what is your ultimate goal ?
27 Apr 2024 17:15 #299199
by vre
Replied by vre on topic odroid h4/h4+
Am searching how to retrofit my mill and lathe
27 Apr 2024 21:52 #299209
Replied by rodw on topic odroid h4/h4+
A few have used the Odroid Hx PC's. My H2+ is fine. I think you only need the entry level H4 for Linuxcnc.
- Thank you received: 5954
27 Apr 2024 22:05 #299212
Replied by tommylight on topic odroid h4/h4+
99$ for the base version seems OK.
Back when Rod suggested it, it was 185$ and that was not OK. The price was not OK, Rod suggesting it was OK.
28 Apr 2024 01:03 #299226
by vre
H4+ has 2 ethernet ports so you can use mesa+ethercat or mesa+internet
28 Apr 2024 06:44 #299234
by blazini36
Replied by blazini36 on topic odroid h4/h4+
Didn't even realize this was coming. Only bummer on the base model is the omission of the 2nd ethernet port. Could do without the rest of the stuff for a machine build, but it might still be worthwhile to use the H4 base and attach a Netcard and have 5 ethernet ports
I'm guessing they use an Intel NIC on the H4 because they redesigned the Netcard to use Intel NICs and Hardkernel generally likes to source the same components for multiple devices. FYI the NetCard is a 4port ethernet card that plugs into the M.2 slot and a BIOS flash changes it from NVME x4 PCIE to 4 straight x1 PCIE. There's no PCIE bridge or anything like that so each Netcard NIC should have no more latency than an onboard NIC
07 May 2024 02:00 - 07 May 2024 02:01 #299990
by vre
5 ethernet ports would be perfect for mesa+ethercat+internet
or the version with 2 ethernet ports+1usb ethernet for mesa+ethercat+internet
Last edit: 07 May 2024 02:01 by vre.
07 May 2024 07:13 #300007
Interesting. I was looking for a little router but had missed that. 6 ports total... and 4 are intel to boot!5 ethernet ports would be perfect for mesa+ethercat+internet
07 May 2024 17:26 #300051
by blazini36
How'd you miss that? The netcard's been out for years, it just used to have 2.5g Realtek NICs. I've been using an H2 with netcard as an OpenWRT router for like 5 years.
Time to create page: 0.214 seconds
