New motherboard w/o parallel port...
28 Aug 2009 03:58 #748
by shotgunn
New motherboard w/o parallel port... was created by shotgunn
Hey guys,
My computer crapped out on me a week or so ago. I bought a new motherboard, and now the computer is all good.
However, the motherboard did not have a parallel port. So I put a PCI parallel card in.
Now EMC2 does not control my steppers. I know that something needs to be done as far as the address of the PCI parallel port.
I am very new to linux so I have no clue how to overcome this. Can someone please give me specific instructions if you know what to do?
Thanx,
shotgunn
Thanx,
shotgunn
28 Aug 2009 07:34 #749
by alex_joni
Replied by alex_joni on topic Re:New motherboard w/o parallel port...
28 Aug 2009 20:22 #751
by shotgunn
Replied by shotgunn on topic Re:New motherboard w/o parallel port...
For some reason I am unable to install the PCI parallel port card. I am certain that it is my linux 'noob-itis'
Can someone please help me understand how to install the PCI card and assign the address.
I have a CD-ROM with Linux drivers, I tried running commands from the terminal, to no avail.
Please help, I need to use my CNC like two days ago.
In the mean time, I will just keep trying.
Thanx,
shotgunn
Thanx,
shotgunn
28 Aug 2009 23:59 #752
Replied by PCW on topic Re:New motherboard w/o parallel port...
Did you go through the steps in:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?NetMos
What was the result of lspci -v?
did your parallel port show up?
29 Aug 2009 01:15 #753
by shotgunn
My results are:
03:09.2 Parallel controller: NetMos Technology Unknown device 9865 (prog-if 03 [IEEE1284])
Subsystem: Unknown device a000:2000
Flags: bus master, medium devsel, latency 0, IRQ 15
I/O ports at dd00
I/O ports at dc00
Memory at fd8fb000 (32-bit, non-prefetchable) [size=4K]
Memory at fd8fa000 (32-bit, non-prefetchable) [size=4K]
Capabilities: <access denied>
I have been to the link you gave. That is where I learned the 'lspci -v'.
I see no other 'steps' to follow after where it tells me 'lspci -v'.
I think the dd00 needs to be e800 and the dc00 needs to say e480. That is what my cards instructions say. I just don't know how to change it.
Please help...
Thanx,
shotgunn
I/O ports at dd00
I/O ports at dc00
Please help...
Thanx,
shotgunn
29 Aug 2009 01:33 #754
The steps are there, basically you use the the 0xdd00 or 0xdc00 address:
loadrt hal_parport cfg="0xdd00" or
loadrt hal_parport cfg="0xdc00" (not sure which one will work)
The addresses in the manual are meaningless, the dd00 and dc00 are the base addresses
of the space allocated by your motherboards BIOS at startup and the one you mus use.
Note that they may change if you change your parallel port card to a different PCI slot
29 Aug 2009 01:49 #755
by shotgunn
how do I change it though?
29 Aug 2009 01:56 #756
by shotgunn
shouldn't it NOT say 'unknown device'
Why does it say that?
29 Aug 2009 02:01 #757
by shotgunn
when I try running that command it says
"bash: loadrt: command not found"
29 Aug 2009 02:48 #758
You cannot change it.
>>shouldn't it NOT say 'unknown device' Why does it say that?
Because there is no driver loaded for that device For NetMos I think this is OK
>> when I try running that command it says bash: loadrt: command not found"
Thats because the loadrt command belongs in the HAL file, not the command line...
