TTL trigger output
09 May 2014 21:55 - 09 May 2014 21:56 #46761
Not quite.
I actually prefer the long-form of the net command, it saves space
Should probably work. (I haven't tested it)
Replied by andypugh on topic TTL trigger output
Does it seem right?
Not quite.
loadrt oneshot count=2
addf oneshot.0 servo-thread
addf oneshot.1 servo-thread
net prog-paused halui.program.is-paused => oneshot.0.in
net take-photo oneshot.0.out => parport.0.pin-09-out
setp oneshot.0.width 0.01
net photo-done parport.0.pin-10-in => oneshot.1.in
net restart-prog oneshot.1.out => halui.program.resume
setp oneshot.1.width 0.002
Last edit: 09 May 2014 21:56 by andypugh.
The following user(s) said Thank You: gillinderglass
- gillinderglass
10 May 2014 01:00 #46771
by gillinderglass
Replied by gillinderglass on topic TTL trigger output
You are fantastic. Thank you. I wouldn't have ever figured this out.
There is just one error. command - (EMC_TASK_PLAN_RESUME) cannot be executed until the machine is out of E-Stop and turned on.
Regards,
Bart
Regards,
Bart
10 May 2014 05:00 #46779
Can you work round that? It sounds like the oneshot fires immediately, before the system is turned on.
If it is a problem, then take the output of the resume oneshot through an and2 component with something like amp-enable.
