set tool offset on tool table change G49. into G43
- RobotMatic
- Topic Author
- Thank you received: 21
15 Mar 2014 02:50 - 15 Mar 2014 02:52 #44817
by RobotMatic
set tool offset on tool table change G49. into G43 was created by RobotMatic
HI.
when the tool offset is set on the tool table, G49 (modal) chages to G43, I can see this in MDI mode in the window of modal commands.
In Fanuc, Fagor, Etc... when I do that operation G49 doesn't change into G43. It's assumed that I am charging a tool offset but Iam not using the tool. The system takes G43 from my program.
In Linuxcnc is difficult to set multiple tools because I have to set G49 every time I charge the tool offset in the tool table.
Why does Linuxcnc work like this?
Last edit: 15 Mar 2014 02:52 by RobotMatic.
15 Mar 2014 07:59 #44829
Setting the tool offset into the tool table actually performs a G10 instruction. Does that help explain what you see?
Replied by andypugh on topic set tool offset on tool table change G49. into G43
15 Mar 2014 18:28 #44841
by BigJohnT
Replied by BigJohnT on topic set tool offset on tool table change G49. into G43
I don't understand why you need to set G49 before touch off. When I touch off a tool I first load the tool with Tn M6 G43 the touch off to my fixture then load the next tool and repeat.
JT
JT
Time to create page: 0.065 seconds
