Having Issues getting G code file to run
06 Jun 2014 00:26 #47730
by ArcEye
Replied by ArcEye on topic Having Issues getting G code file to run
Hi
The code starts immediately with a line including M6 T1
This is completely unnecessary, there are no other tool changes in the code, I would hope you would have the cutter required loaded before you started the program
What may be happening is that the toolchange dialog is hidden by the Axis window, because you were still clicking on Run when it appeared and giving focus to Axis
So it will just sit there, waiting for input to a window you cannot see.
Alt Tab should bring it to the fore, or better still delete the M6 T1 bit and it should run fine
- ts_engraving
06 Jun 2014 01:44 #47732
by ts_engraving
Replied by ts_engraving on topic Having Issues getting G code file to run
Finally Success.....Thanks so much for the help guys. I removed the M6 T1 from the command line and did a save and load command and then hit run and it took off and ran all the way to the end. You can't imagine how happy I was to see this mill run. A little later this evening I'm going to put a piece to aluminum stock in the vise and make my first CNC cut on this machine and I can hardly wait to watch it go. In the future I will be watching for this command and remove them in the beginning. Again......THANKS!!!!!!!!!!
Time to create page: 0.096 seconds
