Horizontal Spindle on 3 Axis
- terans1085
- Topic Author
24 Jun 2014 23:43 #48231
by terans1085
Horizontal Spindle on 3 Axis was created by terans1085
Hi!
I have recently implemented LinuxCNC on a 3 axis woodworking cnc router with multiple spindles.
For the vertical spindle, operation is normal using gcode however the machine is also equipped with a couple of horizontal spindles used to bore horizintally into the sides of the workpiece.
How would you guys go about achieving this? Is there a simple way to 'rotate' the coordinate system temporarily about the X or Y axis? This could be handy so gcode for the vertical spindle can be also used with the horizontal ones.
Thank you!
Thank you!
26 Jun 2014 00:01 #48244
by alan_3301
Replied by alan_3301 on topic Horizontal Spindle on 3 Axis
I don't know if this is possible or would even work.
Maybe when the horizontal spindle is used, a script can swap pins between X and Z step and direction pins.
Then changed back when a vertical tool is used.
I don't know if you can do that on the fly or not, or put it in with a toolchange command, but it seems like it may work.
26 Jun 2014 07:05 #48249
You can create separate configs that allocate different motors to the axes, but you need to stop LinuxCNC and restart to do that.
Do the spindles move up and down? You could use W for the horizontal spindle height then cut in X and Y with them.
Replied by andypugh on topic Horizontal Spindle on 3 Axis
Time to create page: 0.082 seconds
