Cutter compensation problem
- minitreintje
30 Jun 2014 23:55 #48344
by minitreintje
Cutter compensation problem was created by minitreintje
Hi everyone,
I wanted to build a case for an Arduino project with DXF2Gcode & Qcad, so far so good I loaded the design in LinuxCNC 2.5.4 and clicked on 'Play'.
But I get this error:
I already turned it OFF with G40 at the beginning of the Gcode but that doesn't fixed it at all.
Someone who knows a solution for this?
Cheers,
Dylan
Line 30:
Cannot turn cutter comp on when already on.
Cheers,
Dylan
01 Jul 2014 03:05 - 01 Jul 2014 03:05 #48348
by BigJohnT
Replied by BigJohnT on topic Cutter compensation problem
You have G41 or G42 about every few lines with no G40 between them to turn it off.
You should read the User Manual section on cutter compensation.
JT
JT
Last edit: 01 Jul 2014 03:05 by BigJohnT.
Time to create page: 0.272 seconds
