Externally ngc program Selection
- CrazyPenguin
21 Aug 2014 03:16 #50116
by CrazyPenguin
Externally ngc program Selection was created by CrazyPenguin
Hello, my name is Sebastian from Argentina.-
First, I apologise but my english is not good.
I need to do the externally ngc program selection (if it is possible), i.e. select a ncg program "one.ngc" or ncg program "two.ngc" through a classicladder bit.-
thanks in advance.-
thanks in advance.-
21 Aug 2014 16:07 #50133
by ArcEye
Replied by ArcEye on topic Externally ngc program Selection
Hi
The short answer is no, not in classic ladder by itself.
Classic ladder generally works on logic inputs / outputs, responding to switches, triggering solenoids, that type of thing.
There are always other ways to do things using external components that can be triggered by logic inputs.
You will have to explain exactly what you are doing.
I suspect you may be trying to mix classic ladder and gcode for a toolchanger or something like that.
Have you looked at re-mapping?
www.linuxcnc.org/docs/html/remap/structure.html
Time to create page: 0.080 seconds
