M62-M65 and M66 cause error while G42 is on
12 Jan 2015 16:32 #54917
by Nick
M62-M65 and M66 cause error while G42 is on was created by Nick
Why can't we use digital or analog I/O together with cutter compensation is on?
Is it a bug or there's a reason for this error?
12 Jan 2015 20:44 - 12 Jan 2015 20:44 #54930
by ArcEye
Replied by ArcEye on topic M62-M65 and M66 cause error while G42 is on
Hi
Well it is not a bug, it is very deliberate and applies to more than the 2 examples in your post
src/emc/rs274ngc/interp_convert.cc
But the exact reason is not jumping out at me at present
/*! convert_m
Returned Value: int
If convert_tool_change returns an error code, this returns that code.
If input-related stuff is needed, it sets the flag input_flag = true.
Otherwise, it returns INTERP_OK.
Side effects:
m_codes in the block are executed. For each m_code
this consists of making a function call(s) to a canonical machining
function(s) and setting the machine model.
Called by: execute_block.
This handles four separate types of activity in order:
1. changing the tool (m6) - which also retracts and stops the spindle.
2. Turning the spindle on or off (m3, m4, and m5)
3. Turning coolant on and off (m7, m8, and m9)
4. turning a-axis clamping on and off (m26, m27) - commented out.
5. enabling or disabling feed and speed overrides (m49, m49).
6. changing the loaded toolnumber (m61).
Within each group, only the first code encountered will be executed.
This does nothing with m0, m1, m2, m30, or m60 (which are handled in
convert_stop).
int Interp::convert_m(block_pointer block, //!< pointer to a block of RS274/NGC instructions
setup_pointer settings) //!< pointer to machine settings
int type;
double timeout; // timeout for M66
/* The M62-65 commands are used for DIO */
/* M62 sets a DIO synched with motion
M63 clears a DIO synched with motion
M64 sets a DIO imediately
M65 clears a DIO imediately
M66 waits for an input
M67 reads a digital input
M68 reads an analog input*/
if (IS_USER_MCODE(block,settings,5) && ONCE_M(5)) {
return convert_remapped_code(block, settings, STEP_M_5, 'm',
block->m_modes[5]);
} else if ((block->m_modes[5] == 62) && ONCE_M(5)) {
CHKS((settings->cutter_comp_side),
(_("Cannot set motion output with cutter radius compensation on"))); // XXX
CHKS((!block->p_flag), _("No valid P word with M62"));
SET_MOTION_OUTPUT_BIT(round_to_int(block->p_number));
} else if ((block->m_modes[5] == 63) && ONCE_M(5)) {
(_("Cannot set motion digital output with cutter radius compensation on"))); // XXX
CHKS((!block->p_flag), _("No valid P word with M63"));
CLEAR_MOTION_OUTPUT_BIT(round_to_int(block->p_number));
} else if ((block->m_modes[5] == 64) && ONCE_M(5)){
(_("Cannot set auxiliary digital output with cutter radius compensation on"))); // XXX
CHKS((!block->p_flag), _("No valid P word with M64"));
SET_AUX_OUTPUT_BIT(round_to_int(block->p_number));
} else if ((block->m_modes[5] == 65) && ONCE_M(5)) {
CHKS((!block->p_flag), _("No valid P word with M65"));
CLEAR_AUX_OUTPUT_BIT(round_to_int(block->p_number));
} else if ((block->m_modes[5] == 66) && ONCE_M(5)){
//P-word = digital channel
//E-word = analog channel
//L-word = wait type (immediate, rise, fall, high, low)
//Q-word = timeout
// it is an error if:
// P and E word are specified together
CHKS(((block->p_flag) && (block->e_flag)),
NCE_BOTH_DIGITAL_AND_ANALOG_INPUT_SELECTED);
// L-word not 0, and timeout <= 0
CHKS(((block->q_number <= 0) && (block->l_flag) && (round_to_int(block->l_number) > 0)),
NCE_ZERO_TIMEOUT_WITH_WAIT_NOT_IMMEDIATE);
// E-word specified (analog input) and wait type not immediate
CHKS(((block->e_flag) && (block->l_flag) && (round_to_int(block->l_number) != 0)),
NCE_ANALOG_INPUT_WITH_WAIT_NOT_IMMEDIATE);
// missing P or E (or invalid = negative)
CHKS( ((block->p_flag) && (round_to_int(block->p_number) < 0)) ||
((block->e_flag) && (round_to_int(block->e_number) < 0)) ||
((!block->p_flag) && (!block->e_flag)) ,
NCE_INVALID_OR_MISSING_P_AND_E_WORDS_FOR_WAIT_INPUT);
if (block->p_flag) { // got a digital input
if (round_to_int(block->p_number) < 0) // safety check for negative words
ERS(_("invalid P-word with M66"));
if (block->l_flag) {
type = round_to_int(block->l_number);
} else {
type = WAIT_MODE_IMMEDIATE;
if (block->q_number > 0) {
timeout = block->q_number;
} else {
timeout = 0;
(_("Cannot wait for digital input with cutter radius compensation on")));
int ret = WAIT(round_to_int(block->p_number), DIGITAL_INPUT, type, timeout);
//WAIT returns 0 on success, -1 for out of bounds
CHKS((ret == -1), NCE_DIGITAL_INPUT_INVALID_ON_M66);
if (ret == 0) {
settings->input_flag = true;
settings->input_index = round_to_int(block->p_number);
settings->input_digital = true;
} else if (round_to_int(block->e_number) >= 0) { // got an analog input
(_("Cannot wait for analog input with cutter radius compensation on")));
int ret = WAIT(round_to_int(block->e_number), ANALOG_INPUT, 0, 0); //WAIT returns 0 on success, -1 for out of bounds
CHKS((ret == -1), NCE_ANALOG_INPUT_INVALID_ON_M66);
if (ret == 0) {
settings->input_index = round_to_int(block->e_number);
settings->input_digital = false;
} else if ((block->m_modes[5] == 67) && ONCE_M(5)) {
//Q-word = analog value
(_("Cannot set motion analog output with cutter radius compensation on"))); // XXX
CHKS((!block->e_flag) || (round_to_int(block->e_number) < 0), (_("Invalid analog index with M67")));
SET_MOTION_OUTPUT_VALUE(round_to_int(block->e_number), block->q_number);
} else if ((block->m_modes[5] == 68) && ONCE_M(5)) {
(_("Cannot set auxiliary analog output with cutter radius compensation on"))); // XXX
CHKS((!block->e_flag) || (round_to_int(block->e_number) < 0), (_("Invalid analog index with M68")));
SET_AUX_OUTPUT_VALUE(round_to_int(block->e_number), block->q_number);
if ((block->m_modes[6] != -1) && ONCE_M(6)){
int toolno;
bool remapped_in_block = STEP_REMAPPED_IN_BLOCK(block, STEP_M_6);
switch (block->m_modes[6]) {
case 6:
if (IS_USER_MCODE(block,settings,6) && remapped_in_block) {
return convert_remapped_code(block,settings,
STEP_M_6,
'm',
block->m_modes[6]);
} else {
// the code was used in its very remap procedure -
// the 'recursion case'; record the fact
CONTROLLING_BLOCK(*settings).builtin_used = !remapped_in_block;
CHP(convert_tool_change(settings));
break;
case 61:
return convert_remapped_code(block, settings, STEP_M_6,'m',
block->m_modes[6]);
} else {
toolno = round_to_int(block->q_number);
// now also accept M61 Q0 - unload tool
CHKS((toolno < 0), (_("Need non-negative Q-word to specify tool number with M61")));
int pocket;
// make sure selected tool exists
CHP((find_tool_pocket(settings, toolno, &pocket)));
settings->current_pocket = pocket;
settings->toolchange_flag = true;
CHANGE_TOOL_NUMBER(settings->current_pocket);
set_tool_parameters();
break;
default:
if (IS_USER_MCODE(block,settings,6)) {
block->m_modes[6]);
// needs more testing.. once? test tool_change_flag!
//#ifdef DEBATABLE
if (FEATURE(RETAIN_G43)) {
// I consider this useful, so make it configurable.
// Turn it on optionally . -mah
// I would like this, but it's a big change. It changes the
// operation of legal ngc programs, but it could be argued that
// those programs are buggy or likely to be not what the author
// intended.
// It would allow you to turn on G43 after loading the first tool,
// and then not worry about it through the program. When you
// finally unload the last tool, G43 mode is canceled.
if ((settings->active_g_codes[9] == G_43) && ONCE(STEP_RETAIN_G43)) {
if(settings->selected_pocket > 0) {
struct block_struct g43;
init_block(&g43);
block->g_modes[_gees[G_43]] = G_43;
CHP(convert_tool_length_offset(G_43, &g43, settings));
} else {
struct block_struct g49;
init_block(&g49);
block->g_modes[_gees[G_49]] = G_49;
CHP(convert_tool_length_offset(G_49, &g49, settings));
//#endif
if (IS_USER_MCODE(block,settings,7) && ONCE_M(7)) {
return convert_remapped_code(block, settings, STEP_M_7, 'm',
block->m_modes[7]);
} else if ((block->m_modes[7] == 3) && ONCE_M(7)) {
enqueue_START_SPINDLE_CLOCKWISE();
settings->spindle_turning = CANON_CLOCKWISE;
} else if ((block->m_modes[7] == 4) && ONCE_M(7)) {
enqueue_START_SPINDLE_COUNTERCLOCKWISE();
settings->spindle_turning = CANON_COUNTERCLOCKWISE;
} else if ((block->m_modes[7] == 5) && ONCE_M(7)){
enqueue_STOP_SPINDLE_TURNING();
settings->spindle_turning = CANON_STOPPED;
} else if ((block->m_modes[7] == 19) && ONCE_M(7)) {
if (block->r_flag || block->p_flag)
enqueue_ORIENT_SPINDLE(block->r_flag ? (block->r_number + settings->orient_offset) : settings->orient_offset,
block->p_flag ? block->p_number : 0);
if (block->q_flag) {
CHKS((block->q_number <= 0.0),(_("Q word with M19 requires a value > 0")));
enqueue_WAIT_ORIENT_SPINDLE_COMPLETE(block->q_number);
} else if ((block->m_modes[7] == 70) || (block->m_modes[7] == 73)) {
// save state in current stack frame. We borrow the o-word call stack
// and extend it to hold modes & settings.
save_settings(&_setup);
// flag this frame as containing a valid context
_setup.sub_context[_setup.call_level].context_status |= CONTEXT_VALID;
// mark as auto-restore context
if (block->m_modes[7] == 73) {
if (_setup.call_level == 0) {
MSG("Warning - M73 at top level: nothing to return to; storing context anyway\n");
} else {
_setup.sub_context[_setup.call_level].context_status |= CONTEXT_RESTORE_ON_RETURN;
} else if ((block->m_modes[7] == 71) && ONCE_M(7)) {
// M72 - invalidate context at current level
_setup.sub_context[_setup.call_level].context_status &= ~CONTEXT_VALID;
} else if ((block->m_modes[7] == 72) && ONCE_M(7)) {
// restore state from current stack frame.
CHKS((!(_setup.sub_context[_setup.call_level].context_status & CONTEXT_VALID)),
(_("Cannot restore context from invalid stack frame - missing M70/M73?")));
CHP(restore_settings(&_setup, _setup.call_level));
if (IS_USER_MCODE(block,settings,8) && ONCE_M(8)) {
return convert_remapped_code(block, settings, STEP_M_8, 'm',
block->m_modes[8]);
} else if ((block->m_modes[8] == 7) && ONCE_M(8)){
enqueue_MIST_ON();
settings->mist = true;
} else if ((block->m_modes[8] == 8) && ONCE_M(8)) {
enqueue_FLOOD_ON();
settings->flood = true;
} else if ((block->m_modes[8] == 9) && ONCE_M(8)) {
enqueue_MIST_OFF();
settings->mist = false;
enqueue_FLOOD_OFF();
settings->flood = false;
/* No axis clamps in this version
if (block->m_modes[2] == 26)
#ifdef DEBUG_EMC
COMMENT("interpreter: automatic A-axis clamping turned on");
#endif
settings->a_axis_clamping = true;
else if (block->m_modes[2] == 27)
#ifdef DEBUG_EMC
COMMENT("interpreter: automatic A-axis clamping turned off");
#endif
settings->a_axis_clamping = false;
if (IS_USER_MCODE(block,settings,9) && ONCE_M(9)) {
return convert_remapped_code(block, settings, STEP_M_9, 'm',
block->m_modes[9]);
} else if ((block->m_modes[9] == 48) && ONCE_M(9)){
(_("Cannot enable overrides with cutter radius compensation on"))); // XXX
ENABLE_FEED_OVERRIDE();
ENABLE_SPEED_OVERRIDE();
settings->feed_override = true;
settings->speed_override = true;
} else if ((block->m_modes[9] == 49) && ONCE_M(9)){
(_("Cannot disable overrides with cutter radius compensation on"))); // XXX
DISABLE_FEED_OVERRIDE();
DISABLE_SPEED_OVERRIDE();
settings->feed_override = false;
settings->speed_override = false;
if ((block->m_modes[9] == 50) && ONCE_M(9)){
if (block->p_number != 0) {
} else {
if ((block->m_modes[9] == 51) && ONCE_M(9)){
} else {
if ((block->m_modes[9] == 52) && ONCE_M(9)){
ENABLE_ADAPTIVE_FEED();
settings->adaptive_feed = true;
} else {
DISABLE_ADAPTIVE_FEED();
settings->adaptive_feed = false;
if ((block->m_modes[9] == 53) && ONCE_M(9)){
ENABLE_FEED_HOLD();
settings->feed_hold = true;
} else {
DISABLE_FEED_HOLD();
settings->feed_hold = false;
if (IS_USER_MCODE(block,settings,10) && ONCE_M(10)) {
return convert_remapped_code(block,settings,STEP_M_10,'m',
block->m_modes[10]);
} else if ((block->m_modes[10] != -1) && ONCE_M(10)){
/* user-defined M codes */
int index = block->m_modes[10];
if (USER_DEFINED_FUNCTION[index - 100] == 0) {
CHKS(1, NCE_UNKNOWN_M_CODE_USED,index);
enqueue_M_USER_COMMAND(index,block->p_number,block->q_number);
return INTERP_OK;
Last edit: 12 Jan 2015 20:44 by ArcEye.
Time to create page: 0.106 seconds
