Jump over when "execute from here"?
24 Mar 2015 06:29 #57133
by endben
Jump over when "execute from here"? was created by endben
Hi all
Is it possible to jump over some parts in a Programm , when i press "execute from here" in the Axis editor.
for example in NC's from Siemens you can do things like.
IF $P_SEARCH == 1 goto Marke_42
...some code or definition that should not be executed
Marke_42:
Marke_42:
24 Mar 2015 07:44 #57136
There are similar (but different) structures in LinuxCNC G-code:
www.linuxcnc.org/docs/html/gcode/o-code.html
I don't think that there is any way to automatically change the behaviour between run-from-line and normal-run. You could do something a bit strange with something like
N10 #1 = 0
O100 if [0]
N20 #1 = 1
O100 endif
O101 if [#1 EQ 1]
{Do Stuff}
O101 endif
If you start from line N20 then the O101 IF is executed, but under normal conditions it wouldn't be as the O100 IF skips line N20.
Replied by andypugh on topic Jump over when "execute from here"?
Marke_42:
N10 #1 = 0
O100 if [0]
N20 #1 = 1
O100 endif
O101 if [#1 EQ 1]
{Do Stuff}
O101 endif
Time to create page: 0.198 seconds
