sub on timer
14 May 2015 16:10 #58667
by albova
sub on timer was created by albova
hi
is it possible, during a long program, to perform a subroutine every 15 minutes and then resume the program from the point where it left off?
My intention is to control the length of the tool during machining with a probe and if everything is ok resume processing.
thanks
Alessandro
thanks
Alessandro
14 May 2015 17:35 #58668
by BigJohnT
Replied by BigJohnT on topic sub on timer
Not to easy to do based on time but simple to put a subroutine call in your G code and chosen places.
JT
JT
14 May 2015 17:47 #58669
by albova
Replied by albova on topic sub on timer
hi
with gcode can not do it, the process involves writing and the machine works for hours.
The timer is the only solution. If there is a method, I can try even if complicated.
thanks
Alessandro
thanks
Alessandro
14 May 2015 17:57 #58670
by BigJohnT
The problem using a timer (classicladder has the only timer) is you can't just interrupt the G code from the outside. The planner reads in G code and may be several steps ahead of the actual machine. The only way to call a subroutine is from within the G code. If your G code is generated with CAM software then you can change the post processor to insert the subroutine call at chosen points. Of course knowing more about your machine and how you generate G code will lead to better answers.
JT
JT
14 May 2015 19:31 #58677
I don't think that the timer is a solution at all. because I don't think that it can work.
It is relatively easy to stop the program after a fixed time. But how do you start it again?
I do have one idea: You could write a filter-file that runs through the G-code summing up the movement distances and fed rates. After a predefined estimated time it could insert a subroutine call in the G-code.
It is relatively easy to automatically run a filter file on every G-code file as it is loaded.
www.linuxcnc.org/docs/html/config/ini_co...l#sub:FILTER-Section
Replied by andypugh on topic sub on timer
hi
The following user(s) said Thank You: BigJohnT
15 May 2015 00:05 #58693
by albova
hi
your idea is good
I understand the section filter but do not understand what kind of program put.
Moreover, I could work only on the distance traveled, but I need some more explanation.
Ale
your idea is good
Ale
15 May 2015 00:47 #58696
by BigJohnT
You could write the program in just about any language. For me it would be Python. I'd open the file then parse it line by line and insert the sub where it needed to be.
A sample is in the manual.
linuxcnc.org/docs/html/config/ini_config...l#sub:FILTER-Section
JT
JT
Time to create page: 0.261 seconds
