diptrace g code
17 May 2015 12:53 - 17 May 2015 12:56 #58774
by vre
diptrace g code was created by vre
I made a simple circuit in diptrace and the diptrace exported the following g-code file for drilling holes
How to convert to linuxcnc acceptable code ?
Can anyone to modify this code to working code ? After that i will understand the changes and i will write a script that makes diptrace nc drill files compatible with linuxcnc.
M48
METRIC,0000.00
T01C1.1
T01
X+001635Y+002206 // these are the location of holes XY the Z missing also missing G codes for feeding
X+001889Y+002206
X+001762Y+001254
X+001508Y+001254
X+001254Y+001254
X+002016Y+001254
X+002270Y+001254
T00
M30
Last edit: 17 May 2015 12:56 by vre.
17 May 2015 16:21 - 17 May 2015 17:24 #58778
by ArcEye
Replied by ArcEye on topic diptrace g code
There is not much there
M48 is to do with feed override in LCNC so irrelevant
Have to guess that next line sets units and the scale
METRIC,0000.00
G21 G17 is all you need here plus
G90 G40 G54 G8
Again guessing, that next line sets the diameter of tool 1
T01C1.1
Don't need that, it should be in your tool table and you are no applying compensation anyway
Don't need the percent sign %
T01 presumably equates to
M6T1
G43
Then you need to work out what these values actually are, ie where the decimal place is.
I am guessing that the scale given earlier means that
X+001635
means
X16.35
If the values make sense to you converted to that scale, just needs the rest of the program
Quite honestly the output is so little you might as well just use the values as hole locations and write the rest, not much point trying to convert it.
Something like
METRIC,0000.00
G90 G40 G54 G8
T01C1.1
M6T1
G43
X+001635
means
X16.35
Something like
G17 G21
G90 G54 G40 G8
M6T1
G43
M3 S1000
G0 X0 Y0 Z2
G0 X16.35 Y22.06
G01 Z-1 F100
G0 Z2
(and so on for each hole)
G0 X0 Y0 Z2
M5
M2
Last edit: 17 May 2015 17:24 by ArcEye.
The following user(s) said Thank You: vre
17 May 2015 19:29 - 17 May 2015 19:30 #58786
by BigJohnT
Replied by BigJohnT on topic diptrace g code
If you just need to drill holes and know their location you can use my G code generator to get valid G code.
gnipsel.com/files/mill-g-code/
Being a work in slow progress not all the functions work but all the hole Ops functions including tapping work.
JT
JT
Last edit: 17 May 2015 19:30 by BigJohnT.
17 May 2015 20:57 #58790
by vre
Replied by vre on topic diptrace g code
diptrace has option to output mach3 g code and the output of this function (same pcb) is
(G code for Mach2/3)
(T01 C1.1)
T01 M06 M03 G43 H1 S10000
G81 X6,35 Y12,065 Z-1,905 R2,54 F10
X8,89 Y12,065
X7,62 Y2,54
X5,08 Y2,54
X2,54 Y2,54
X10,16 Y2,54
X12,7 Y2,54
G00 Z10.0
M02
17 May 2015 21:03 #58791
by ArcEye
The locations are 10mm out from the last ones and all the commas should be decimal points,
but otherwise should run.
Try it in a simulator
18 May 2015 06:08 - 18 May 2015 06:08 #58804
by vre
What about creating a meaningfull metalanguage in c style for G/M linuxcnc codes?
C know very much people g code very little number of people
Last edit: 18 May 2015 06:08 by vre.
18 May 2015 07:13 #58807
by dgarrett
Replied by dgarrett on topic diptrace g code
see: www.vagrearg.org/content/gcmcWhat about creating a meaningfull metalanguage in c style for G/M linuxcnc codes?
18 May 2015 17:40 #58816
by BigJohnT
All the machinists in the world know G code and they probably out number the programmers...
JT
JT
Time to create page: 0.081 seconds
