Need a HELP on G-Code
20 Jan 2016 04:41 #68797
by SKH
Replied by SKH on topic Need a HELP on G-Code
Thank you for all your support, guys.......We did manage to manipulate the robot successfully .
but now we needed to setup acceleration and deceleration of the robot when navigating,
right now we know there is a function to setup acceleration.but
Q1)how to setup deceleration?
Q2)we are currently using 3 parallel ports in the system.is it not good to use the parallel port for this application.(we mean ,is there any data propagation issues,like delays,data misplacements,etc)
Q3)what are the advantages of the MESA card over the parallel port.
- Thank you received: 1370
20 Jan 2016 13:47 - 20 Jan 2016 13:54 #68815
A1) Deceleration is just negative acceleration, and is handled by the same code as the acceleration. (once you set up one you have both)
A2) The limitation of a parallel port is in the rate that it can be serviced by the software, (your base thread speed)
A3) The advantages of a 5i25, are:
1-Hardware step and pulse generation at up to MHz speeds. (as opposed to software stepping at the base thread rate and its associated granularity)
2-Hardware encoder reading at up to MHz speeds .(same as above)
3-Mesa's daughter card selection offering specialized io (analog, digital, differential,...), and huge quantities of GPIO(general purpose I/O) options
Replied by Todd Zuercher on topic Need a HELP on G-Code
Last edit: 20 Jan 2016 13:54 by Todd Zuercher.
The following user(s) said Thank You: SKH
- marq_torque
07 May 2016 06:46 - 20 May 2016 11:02 #74330
by marq_torque
Replied by marq_torque on topic Need a HELP on G-Code
Hello ArcEye,
Thanks for Script first, i am stuck at how to capture code in file ? can you help modding this script ? i need axis letters which i got from your modified lines but its also throwing 0 0 1 0 at the end of each line and not sure where file is being saved !
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...54;hb=refs/heads/2.7
#!/usr/bin/python
"""Usage:
python teach.py nmlfile outputfile
If outputfile is not specified, writes to standard output.
You must ". scripts/rip-environment" before running this script, if you use
run-in-place.
# Copyright 2007 Jeff Epler <jepler@unpythonic.net>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
import linuxcnc
import Tkinter
import sys
linenumber = 1;
if len(sys.argv) > 1:
linuxcnc.nmlfile = sys.argv[1]
if len(sys.argv) > 2:
outfile = sys.argv[2]
sys.stdout = open(outfile, 'w')
s = linuxcnc.stat()
def get_cart():
s.poll()
position = " ".join(["%-8.4f"] * s.axes)
return position % s.position[:s.axes]
def get_joint():
s.poll()
return position % s.joint_actual_position[:s.axes]
def log():
global linenumber;
if world.get():
p = get_cart()
else:
p = get_joint()
label1.configure(text='Learned: %s' % p)
print linenumber, p, s.flood, s.mist, s.lube, s.spindle_enabled;
linenumber += 1;
def show():
s.poll()
if world.get():
p = get_cart()
else:
p = get_joint()
label2.configure(text='Position: %s' % p)
app.after(100, show)
app = Tkinter.Tk(); app.wm_title('LinuxCNC Teach-In')
world = Tkinter.IntVar(app)
button = Tkinter.Button(app, command=log, text='Learn', font=("helvetica", 14))
button.pack(side='left')
label2 = Tkinter.Label(app, width=60, font='fixed', anchor="w")
label2.pack(side='top')
label1 = Tkinter.Label(app, width=60, font='fixed', text="Learned: (nothing yet)", anchor="w")
label1.pack(side='top')
r1 = Tkinter.Radiobutton(app, text="Joint", variable=world, value=0)
r1.pack(side='left')
r2 = Tkinter.Radiobutton(app, text="World", variable=world, value=1)
r2.pack(side='left')
show()
app.mainloop()
Last edit: 20 May 2016 11:02 by BigJohnT. Reason: add code tags
19 May 2016 17:26 - 19 May 2016 17:27 #74858
by jstoquica
Replied by jstoquica on topic Need a HELP on G-Code
How can I see the output file "train.ngc"?
or
How can I generate it?
I tried "python train.py /tmp/train.ngc", but the file doesn't exist.
Thanks.
or
#!/usr/bin/python
"""Usage:
python train.py
You must ". scripts/emc-environment" before running this script, if you use
run-in-place.
import hal
import sys
import linuxcnc
s = linuxcnc.stat()
def get_cart():
s.poll()
position = "G01 X%-8.4f Y%-8.4f Z%-8.4f A%-8.4f B%-8.4f C%-8.4f\n" % ( s.position[0], s.position[1], s.position[2], s.position[3], s.position[4], s.position[5] )
return position
h = hal.component("train")
h.newpin ("record", hal.HAL_BIT, hal.HAL_IN)
outfile = "train.ngc"
h.ready()
try:
while 1:
if h["record"] == 1:
f = open(outfile, 'a')
pos = get_cart()
f.write(pos)
f.close()
except KeyboardInterrupt:
raise SystemExit
Thanks.
Last edit: 19 May 2016 17:27 by jstoquica.
20 May 2016 11:05 #74875
by BigJohnT
Replied by BigJohnT on topic Need a HELP on G-Code
From the first few lines of train.py
JT
train.py does not take any arguments."""Usage:
python train.py
JT
20 May 2016 14:58 #74883
by jstoquica
Hi John,
Thanks for the reply.
Then, How can I see or generate the output file of that script?
Thanks.
h.ready()
try:
while 1:
pos = get_cart()
f.write(pos)
f.close()
Thanks.
- thefabricator03
- Thank you received: 531
16 Sep 2019 03:38 #145311
by thefabricator03
Replied by thefabricator03 on topic Need a HELP on G-Code
SKH,
This might be a long shot since this thread is thee years old but do you have any more pictures of you robotic arm? It is a very interesting design.
