#<_hal[custom.pin]> not defined
- bkt
- Thank you received: 114
Near line....
/home....../../../file.ngc
Named Parameter
#<_hal[custom.pin]> not definedI use the value of out bit parameter from my custom comp in a if loop in my gcode ... the gcode is present as start code in myini.ini file ... Is possible to solve these warning (I need start with these program ... I've not choice) ... i just try to use my gcode as soubroutine ... but obviously is the same ...
In My header custom comp there is these line:
pin out bit mypin "comment"; /* my first version whit error*/
pin out bit mypin = 0 "comment"; /* my second version whit error, actually I use these*/Regards
giorgio
- Thank you received: 4636
linuxcnc.org/docs/2.7/html/remap/remap.h...i_file_configuration
Be aware of the warnings here:
linuxcnc.org/docs/2.7/html/remap/remap.h...ap:referto-hal-items
Your ,comp sample seems to create two pins with the same name. That probably won't work.
- bkt
ini file ... open_file = ""
than when axis (or in my case nogui gui
ssh user@server-name-here /path/to/command arg1and use these script on remote machine..
#! /usr/bin/python
import sys
import linuxcnc
myprog = str(sys.argv[1])
c = linux.command()
c.mode(linuxcnc.Mode_AUTO)
c.reset_interpreter()
c.program_open('/home/myfolder' + myprog + '.ngc')if you prefer can use as argv the complete name file or path complete name file (example /home/myfolder/myngc.ngc) ... so the last row become:
c.program_open( myprog )that's all folks ...
If there are a more secure and elegant method I hope that someone me indicates ....
Regards
giorgio
- bkt
You need to activate reading HAL pins from G-code:
for version 2.6 is the same??
Regards
Giorgio
- bkt
there is not my case .... I have only one but set as io .....Your ,comp sample seems to create two pins with the same name. That probably won't work.
Regards
Giorgio
- bkt
FEATURES = 28
So I think these is not the real problem .... i suspect that: custom pin is read after call of my custom comp. My custom ccomp is read from custom_hal.hal .... custom_hal.hal is read after myhal.hal..... so when gcode is parse.... my custom comp do not exist..... probabily if can loadrt mycustomcomp in myhal the problem disappear..... tomorrow i try these
Regarfs
Giorgio
