4th Axis Wrapped contour
20 Dec 2016 03:01 #84443 by Duc
4th Axis Wrapped contour was created by Duc
Looking for insight on writing some G-code to flute a barrel. I could drop this into a CAM program but would rather learn a new skill.
Here is a example video of what Im looking to do. Would also like to build a cam cylinder later on.
I'm not seeing a Gcode to wrap a xy move to the A -axis, I know Haas and others may have a code or macro for this function.
Parameters
First cut starts at A0.0
2 full rotations in 20 inches
Start at X-.1 Y0
End at X20.1 Y0
DOC .020 each pass Final depth .10
20 Dec 2016 06:02 - 20 Dec 2016 06:29 #84445 by Todd Zuercher
Replied by Todd Zuercher on topic 4th Axis Wrapped contour
Seems like a simple enough job to program.
for one flute cutting .02 deep in both directions, something like this:
(untested code)
g17g20g90
#1 = 0.02 (depth per pass)
#2 = 0.1 (final depth)
#3 = 720 (degrees of rotation)
#4 = 0.1 (X start)
#5 = 20.1 (X end)
#6 = 0 (surface)
#7 = [#6 - #2]
g0 x[#4] y0 z[#6+0.1] a0
#6 = [#6 - #1]
o100 do
g1 z[#6]
g1 x[#5] a[#3]
#6 = [#6 - #1]
o110 if [#6 LT #7]
o100 break
o110 endif
g1 z[#6]
g1 x[#4] y0 z0.1 a0
#6 = [#6 - #1]
o100 while [#6 GE #7]
The code will need modified a little if your machine is configured for a wrapped rotary.
If you want it to do multiple flutes like in the video, you'll need to wrap this in another while loop and add a couple more parameters to index the angle for each flute.
Last edit: 20 Dec 2016 06:29 by Todd Zuercher.
21 Dec 2016 02:51 #84480 by Duc
Replied by Duc on topic 4th Axis Wrapped contour
Modified the code in a way I believe will allow flutes to place all the way around a barrel based on defined variables. Will try it out tomorrow.
Is there anyway to watch the variables that are used in the o-codes during machining?
g17g20g90
#4 = 0.1 (X start)
#5 = 20.1 (X end)
#6 = 0 (surface)
#8 = 4 (Number of flutes)
#9 = 0 (degree of rotation)
#10 = 10 (Feed rate)
;Calculations
#71 = [#6 - #2] (current depth)
#101 = [360/#8]  (Angle between fluting)
g0 Y0 X0 Z.1
o100
g0 A[#9]   (Position rotary before cut)
	o110 do
		M3 S150
		#6 = [#6 - #1]  (Depth of Z for cut)
		g1 F10 x[#4] y0 z[#6] a[#3+#9]  (Cutting)
		g0 z.1  (Raise before home move)
		g0 x[#4] y0  a[0+#9] (Move to home position)
		#6 = [#6 - #1] (Increase variable depth of Z for cut)
	o110 while [#6 GT #71]   (End loop when depth of cut is reached)
#9 = [#9+#101]  (Set up next rotation angle)
o100 while [#9 GE 360]
M2
21 Dec 2016 03:47 #84481 by Todd Zuercher
Yes, you can use the (DEBUG,...) command in your code to print the value of the parameters during the run.
Like this
g17g20g90
#4 = 0.1 (X start)
#5 = 20.1 (X end)
#6 = 0 (surface)
;Calculations
g0 Y0 X0 Z.1
o100
(DEBUG, A = #9)
	o110 do
		M3 S150
		(DEBUG, cutting dept for next pass is #6)
M2
Just insert the debug line where ever you want to, and it can print what ever message and parameter values you like.
Here is a link to a tutorial.
gnipsel.com/linuxcnc/g-code/gen02.html
23 Dec 2016 22:58 - 24 Dec 2016 01:09 #84652 by Duc
Ok final version of the code for anyone that needs it. Had to work a few bugs out of it.
Coolant will need to be added and feeds adjusted for your machine.
Thank you for the help
[Fixing code, will have it up tomorrow]
Last edit: 24 Dec 2016 01:09 by Duc.
25 Dec 2016 20:13 - 25 Dec 2016 20:14 #84686 by Duc
Motion has been tested but not used just yet. Just fill in #1-#11 with the required numbers.
Barrel fluting with a ball nose end mill. Touch off on top middle of barrel for your zero.
g17g20g90
#2 = 0.04 (final depth)
#3 = 120 (degrees of rotation)
#4 = 0.1 (X start)
#5 = 10.1 (X end)
#6 = 0 (surface)
#8 = 1 (Number of flutes)
#9 = 90 (Starting degree of rotation)
#11 = 0 (Spindle RPM)
;Calculations
#202 = [#3 * 101 + 9]
g0 Y0 X0 Z.1
o100 do
(DEBUG, A = #9)
	o110 do
		M3 S#11
		M8
		g1 F10 z[#6]
		g1 F10 x[#5] y0  a[#3+#9]  (Cutting)
	o110 while [#6 GE -#2]   (End loop when depth of cut is reached)
(DEBUG, A= #9 Rotation angle)
#6 = 0 (Reset cutting depth to surface)
o100 while [#9 LT 360]
M2
Barrel fluting with slotter from the side. Touch off from middle side of the slotter. This one moves from the negative value to positive.
g17g20g90
#3 = 120 (Total rotation of cut)
#4 = 0.1 (X start)
#5 = 10.1 (X end)
#6 = 0 (touch off surface in Y)
#9 = 60 (starting degree of rotation)
;Calculations
#202 = [#8 * #101 + #9] (Stopping angle for machining)
g0 Y-.5 X0 Z0
o100 do
#6 = [#6 + #1]  (Depth of Y for cut)
(DEBUG, A = #9)
	o110 do
		M3 S[#11]
		M8
		g1 F[#10] Y[#6]
		g1 F[#10] x[#5]  a[#3+#9]  (Cutting)
		g0 Y-.1  (Move away from part before home move)
		g0 x[#4]  a[0+#9] (Move to home position)
		#6 = [#6 + #1] (Increase variable depth of Y for cut)
	o110 while [#2 GE #6]   (End loop when depth of cut is reached)
o100 while [#9 LT #202]
M9
M2
Last edit: 25 Dec 2016 20:14 by Duc.
Time to create page: 0.149 seconds
