Remapping M100-M199 in Python
15 May 2017 22:06 #93243
by DaBit
Remapping M100-M199 in Python was created by DaBit
I was trying to implement a couple of FDM 3D-printer M-codes, such as M104 (set extruder temperature) using remapping to a Python function.
Now, this works for available G-codes and M-codes outside the 100-199 range. If I do this:
(ini file)
(./python/remap.py)
Then using M104 in a program results in 'undefined M code'.
If I remap M204 it works fine.
Now, it is not a total disaster since one must translate reprapwhatever flavor G-code to LinuxCNC G-code anyway (or adapt the slicer), but to be honest I expected some sort of hierarchy like 'if the M1xx code is remapped using python/ngc use that, else try to find the user script, else error'.
MachineKit seems to do just that: (click, around line 629) . Is it possible to obtain the same behaviour with LinuxCNC master?
(ini file)
[RS274NGC]
REMAP = M104 modalgroup=10 py=testfunc
(./python/remap.py)
def testfunc(self, **words):
print "Hello there!"
17 May 2017 21:27 #93316
Replied by andypugh on topic Remapping M100-M199 in Python
This is actually very easy, and doesn't need remap.
Just create an executable python file (start the file with #! /usr/bin/python ) which contains your python code. Then call it M104
The M-codes from 100 to 199 simply execute a file of that name, and python files count as executable.
18 May 2017 15:46 #93356
by DaBit
Replied by DaBit on topic Remapping M100-M199 in Python
Yes, I know, but it is less flexible. Only P and Q parameters, less control over interpreter; cannot choose whether the code is a queuebuster or not for example, and I have to do the remapping of e.g. M84 in ngc or python anyway. And I hate the 15 different files with 10 lines of code each, but that's not the real reason, oh nooooo..
Not sure how to do AIO/DIO (M66 & companions) in script. Something like import emccanon; emccanon.SET_AUX_OUTPUT_BIT(xx) I presume?
Remapping is a nice feature, I only don't like all the exceptions and special cases. Should be a generic thing imho.
19 May 2017 12:35 - 19 May 2017 12:51 #93380
by bevins
Replied by bevins on topic Remapping M100-M199 in Python
This works for me.
Map your motion.digital-out-xx in hal
Map your motion.digital-in-XX in hal
This works extremely well.
import linuxcnc
from interpreter import *
from emccanon import MESSAGE, SET_MOTION_OUTPUT_BIT, CLEAR_MOTION_OUTPUT_BIT,SET_AUX_OUTPUT_BIT,CLEAR_AUX_OUTPUT_BIT
def M6_Remap(self, **words):
# if in preview mode exit without doing anything and all ok
if self.task==0:
return INTERP_OK
try:
self.execute("M65 P2")
self.execute("M66 P5 L3 Q5")
self.execute("M65 P3")
Last edit: 19 May 2017 12:51 by bevins.
- sqmathlete
- Thank you received: 16
07 Feb 2018 17:05 #105534
by sqmathlete
Replied by sqmathlete on topic Remapping M100-M199 in Python
I am trying to implement something similar to Bevins' python code to contol M1XX but, I keep getting an "interpreter module does not exist" error.
my .ini is in ~/linuxcnc/configs/ecat-lathe
m-code files M138 ~/linuxcnc/configs/ecat-lathe/m-codes
python files ~/linuxcnc/configs/ecat-lathe/python note: toplevel.py has only one line import remap. The the file remap.py is also in the same folder as toplevel.py and begins with #!/usr/bin/python, then Bevins code.
In the .ini file I added
[RS247_NGC]
REMAP = M138 modal group=10 python=M138
[PYTHON]
PATH_PREPEND= python
# import the following Python module
TOPLEVEL= python/toplevel.py
I don't know if this matters but I created a button in the custom pyvcp side panel that calls the M1XX code. Interestingly, if the M-code is defined as #!/bin/bash and uses the waitfor method on the wiki, the custom m-code will work but requires a lot of ladder logic to cover timeout faults and then there is the issue of connecting multiple faults to halui.abort.
Python is obviously the way to access and execute.command()s such as abort over mutiple fault scenarios. However, I just can't seem to sort out the remap magic. Similar to this thread is forum.linuxcnc.org/20-g-code/33642-custom-m-code-python. Either way some wizardry is required.
Any help would be greatly appreciated,
[RS247_NGC]
[PYTHON]
26 Feb 2018 20:28 #106557
Sorry for the late reply.
When do you see the error "Interpreter module does not exist". Is it when you start LinuxCNC or when you call the M-code?
- sqmathlete
26 Feb 2018 23:06 #106579
by sqmathlete
Hi Andy,
All good! I see the error when linuxcnc starts up.
27 Feb 2018 00:38 #106589
Interesting.
I think that means that the remap file is being found.
What happens if you comment-out the "from interpreter import *" line in your code?
(And is that what the offending line actually says)
- sqmathlete
01 Mar 2018 05:18 #106792
by sqmathlete
It does seem like the remap.py file is being seen. After I commented out " from interpreter import * "
and ran linuxcnc in a terminal I get the following
I also tried the other way that you suggested earlier "an executable python file" in my m-codes folder (M140). Linuxcnc will start up fine but if I import either the interpreter or emccannon module I get an error saying that these modules
/linuxcnc-dev/configs/ecat-lathe-1.0/ecat-lathe-1.0.ini:66: executing 'import sys
sys.path.insert(0,"python")'
PythonPlugin: Python '2.7.3 (default, Nov 24 2017, 16:38:25)
[GCC 4.7.2]'
is_callable(remap.m141) = TRUE
NML_INTERP_LIST(0x82f94e8)::append(nml_msg_ptr{size=88,type=EMC_TRAJ_SET_G5X}) : list_size=2, line_number=0
NML_INTERP_LIST(0x82f94e8)::append(nml_msg_ptr{size=84,type=EMC_TRAJ_SET_G92}) : list_size=3, line_number=0
NML_INTERP_LIST(0x82f94e8)::append(nml_msg_ptr{size=20,type=EMC_TRAJ_SET_ROTATION}) : list_size=4, line_number=0
is_callable(__init__) = FALSE
Bad character ',' used
Interpreter stack: - int Interp::read_one_item(char*, int*, block_pointer, double*) - int Interp::read_items(block_pointer, char*, double*) - int Interp::parse_line(char*, block_pointer, setup_pointer) - int Interp::_read(const char*)
emcTaskPlanInit() returned 5
is_callable(__delete__) = FALSE
Trying to fix bindings Left PrevChar {}
Trying to fix bindings Right NextChar {}
Trying to fix bindings Up PrevLine {}
Trying to fix bindings Down NextLine {}
Trying to fix bindings Home LineStart {}
Trying to fix bindings End LineEnd {}
note: MAXV max: 250.000 units/sec 15000.000 units/min
note: LJOG max: 250.000 units/sec 15000.000 units/min
note: LJOG default: 50.000 units/sec 3000.000 units/min
waiting for s.joints<0>, s.kinematics_type<0>
A configuration error is preventing LinuxCNC from starting.
More information may be available when running from a terminal.
Issuing EMC_SYSTEM_CMD -- ( +30,+268, +0,m-codes/M140\032-1.000000\032-1.000000,)
Emit interp-run
Emit interp-run
File "m-codes/M140", line 4, in <module>
ImportError: No module named interpreter
emcSystemCmd: system command 2785 exited abnormally with value 1
01 Mar 2018 13:00 #106797
For reasons I am not 100% clear on you can't import emccannon or interpreter into a standalone Python script, they are only available inside code that is part of a remap.
This looks fishy: Bad character ',' used
