Parameter modifier of ":" -- documented?
  • GaryLa
  • Topic Author
  • Senior Member
  • Senior Member
8 years 10 months ago - 8 years 10 months ago #103375 by GaryLa
The files move.ngc and line.ngc have a parameter format I've not seen before. Chapter 3 of the documentation doesn't mention this format either.
Is it a "member" modifier allowing a variable to have members like structures have? If so, what declarations (if any) are necessary?
Or, is it just to reference a local var from another function? If so, then why does move reference its own locals this way?
BTW, the format is #<variable:mystery> and used as:
#<variable:mystery> = value
Last edit: 8 years 10 months ago by GaryLa.
8 years 10 months ago #103377 by dgarrett
Replied by dgarrett on topic Parameter modifier of ":" -- documented?
The use of global names like #<_line:len>,
#<_move:phi> is just a convention used for
communication of results in some of the provided
ngcgui examples and for handling of entry boxes.
From the docs:
While input global named parameters are discouraged, linuxCNC subroutines must use global named parameters for returning results. Since ngcgui-compatible subfiles are aimed at gui usage, return values are not a common requirement. However, ngcgui is useful as a testing tool for subroutines which do return global named parameters and it is common for ngcgui-compatible subfiles to call utility subroutine files that return results with global named parameters. To support these usages, ngcgui ignores global named parameters that include a colon (:) character in their name. Use of the colon (:) in the name prevents ngcgui from making entryboxes for these parameters.
Ref: linuxcnc.org/docs/2.7/html/gui/ngcgui.html
The source file text gives some more background:
# The linuxcnc gcode language does not provide a # mechanism for returning results so subroutines # must set global parameters for results. Within # ngcgui, _globals with names that contain a colon # (:) character are ignored in the creation of # entry boxes. For example, a subroutine called # from a Subfile named o<line> returns results in # globals like: #<_line:theta>, $<_line:length>, # etc. This feature can be used to hide globals # from entry boxes for any purpose or for # communication between routines
Ref: github.com/LinuxCNC/linuxcnc/blob/2.7/tcl/ngcgui.tcl#L89
The following user(s) said Thank You: GaryLa
Time to create page: 0.038 seconds
