Cutting a tapered thread with G76
09 Oct 2018 23:36 #118608
by JR1050
Cutting a tapered thread with G76 was created by JR1050
I am baffled with how the tapered thread command of lcnc works. I have a 16mm Id thread, the last half of the thread is in a collet that is clamped causing the thread to be deformed and tapered , smaller on the back end. I'd like to program the taper out, which on fanuc lathes was a an I value, which was the dia distance between the minors at either end of the taper.
I need to program about .003 on the dia over and inch.
My present command
G76 P.059K.075I-.01Q0 H3
How is this done?
My present command
How is this done?
10 Oct 2018 13:32 #118638
Replied by andypugh on topic Cutting a tapered thread with G76
You can't (currently) do a constant-taper thread with G76.
But it sounds like you only need an exit taper?
linuxcnc.org/docs/2.7/html/gcode/g-code.html#gcode:g76
E and L control the taper, but only the distance over which it occurs. It is always a taper from full depth of thread to zero depth of thread.
If you want a straight taper then you can use G33 and programme each pass separately.
Or there is this experimental work (and discussion)
sourceforge.net/p/emc/mailman/emc-develo...any.com/#msg35333774
- CNCCustoms
03 Oct 2019 13:56 #146978
by CNCCustoms
Replied by CNCCustoms on topic Cutting a tapered thread with G76
Hi
Has this been resolved? Can Linuxcnc do tapered threads with G76 now?
Thanks,
Thanks,
03 Oct 2019 16:06 #146991
I don't think anything further has happened You could try joining the conversation on the mailing list. The multispindle letter clash has been resolved now.
12 Aug 2020 15:43 #178041
by RotarySMP
Replied by RotarySMP on topic Cutting a tapered thread with G76
Bump...
Can LinuxCNC still not tapered threads?
Mark
Mark
12 Aug 2020 17:19 #178047
You can do it with G33
I don’t know what happened to the tapered G76 work.
12 Aug 2020 17:27 #178048
by RotarySMP
Thanks for the quick response Andy,
Bummer. Now I have to write a subroutine to do it with G33, and you have seen how careless my code is I will take me an hour to write it and two to debug. Good practice.
Mark
Mark
28 Jan 2021 01:25 #196872
by mooser
Replied by mooser on topic Cutting a tapered thread with G76
Just wondering if this was ever resolved as I need to cut a 1/8-pipe thread on some parts? (tried a 2 line G76 but it complained about missing move axis)
M
M
- Thank you received: 5979
28 Jan 2021 01:41 #196874
Replied by tommylight on topic Cutting a tapered thread with G76
28 Jan 2021 02:35 #196879
by mooser
I don't think I've ever used a G33 in my life...
I need to make a 1/8-27 npt go up and then become a 5/16- 24 straight so maybe it's time to learn
M
M
