Custom M code in Python example?
01 Nov 2019 20:50 #149388
by scotta
Custom M code in Python example? was created by scotta
Hi, I'm using custom M codes for my 3D printer work. Currently they are bash scripts but I'm wondering if anyone has a working example of a Python based M code?
Bash works but it's getting old school now and the syntax is not as intuitive. And you don't have to do work arounds to use floating point maths.
Being able to set Hal pins directly without having to create a component and then do the Hal wiring would be great. An example of one of my M codes.
Greatly appreciated.
Scott
#!/bin/bash
# M109 in your G code program will run the Linux commands in this
# shell script "batch" file, passing the P and Q variables as command
# line arguments.
# M code to set EXTRUDER 0 temperature and wait until temperature has been reached
echo "Usage: M109 Pn - where n is the temperature"
# give the command line arguments descriptive names
P=$1
#Q=$2
TOLERANCE=0.5
PV=$(halcmd gets ext0-PV)
halcmd sets ext0-SP $P
#bash cannot do floating point comparison
SP=$(echo "($P-$TOLERANCE)"| bc -l)
delta=`echo "scale=3; ($PV < $SP)"| bc -l`
while [ "$delta" != "0" ]
do
sleep 1
done
echo "Temperature reached"
# if a M1nn command exits with nonzero status,
# the gcode program exits. So always exit 0.
exit 0 ;# 0 for success
Scott
02 Nov 2019 00:12 #149399
Replied by cmorley on topic Custom M code in Python example?
What version of linuxcnc are you using?
02 Nov 2019 19:24 #149439
by scotta
Replied by scotta on topic Custom M code in Python example?
Hi Chris,
I'm using LINUXCNC - 2.8.0~pre1 on RPi with custom SPI interface component to an "off the shelf" 3D printer control board running my custom firmware. Currently called spiPRU but that's not a sexy name, maybe Remora firmware..
Is there more options in 2.9?
Scott
Scott
02 Nov 2019 21:22 #149444
No there are less in 2.7 (2.8 and master are then same right now)
#!/usr/bin/env python
import sys
import hal
tempcomp = hal.component("_dummy_")
value = hal.get_value("ext0-PV")
print value
variable = sys.argv[1]
print variable
hal.set_p('ext0-PV', '%s'%variable)
02 Nov 2019 22:10 #149447
by scotta
Hi Chris,
Thanks for the quick response and example code. I note the 2.8 docs have the hal.get_value. I'd been looking at 2,7 docs.
Will try and convert my custom M codes over now. Thanks!!
Scott
Scott
02 Nov 2019 22:30 #149449
by scotta
Hi Chris,
Are there any plans to implement a hal.set_s to be able to set a signal?
For the moment I'll create pins that can be set by the M codes.
Scott
Scott
02 Nov 2019 22:36 #149450
There is no plans by me My reasoning is you usually set a signal because you want to have a pin drive another. Once you connect a driving pin you can no longer set the signal.
Though it's probably not that much work to add it - I'm just not very good with c++ code.
03 Nov 2019 05:35 #149468
by scotta
Hi Chris,
Not sure what I'm doing wrong but regardless if I set the created pin to HAL.OUT, HAL.IN or HAL.IO I get a Runtime error?
If I use HAL_OUT I get "pin not writable"
If I use HAL_IN I get "pin connected to signal"
I have a custom.hal file that creates the signal to my destination pin.
Appreciate your help here.
Scott
#!/usr/bin/env python2
# Note! Change the above python2 to python is not using Arch Linux
# M104 in your G code program will run the python code in this file,
# passing the P and Q variables as command line arguments.
import sys
import hal
h = hal.component("M104")
print "Usage: M104 Pn - where n is the Extruder temperature"
P = sys.argv[1]
Q = sys.argv[2]
print P
print Q
h.newpin("PV", hal.HAL_FLOAT, hal.HAL_IO)
hal.connect("M104.PV", "BLtouch-SP")
hal.set_p("M104.PV", "%s"%P)
# spiPRU command outputs
net bed-heater-SP => spiPRU.SP.0
net ext0-heater-SP => spiPRU.SP.1
net ext0-cooling-SP => spiPRU.SP.2
net BLtouch-SP => spiPRU.SP.3
Scott
03 Nov 2019 05:54 #149469
The component gets destroyed each time the script ends.
This includes the HAL pins built by it.
So use the script to manipulate pin values or to read pin values but don't make pins.
If you need component with pins, build it separately and use the script to manipulate it.
Chris
Chris
03 Nov 2019 06:04 #149470
by scotta
The following two methods work. For some reason set_p does not play right?
or
Scott
h.newpin("PV", hal.HAL_FLOAT, hal.HAL_IN)
h['PV'] = P
or
msg=Popen('halcmd net BLtouch-SP M104.PV', shell=True, stdout=PIPE).stdout.read()
h['PV'] = P
Scott
Time to create page: 0.080 seconds
