G53 and G54
18 Sep 2020 17:06 #182664
by nf1z
G53 and G54 was created by nf1z
Not sure if this is a bug or "works as designed". In any event it was unexpected to me and undocumented and may cause some nasties.
I was testing the behaviour of G38.2 for tool probe use. What I wanted to do was something like:
G53 G38.2 Z-10
(as the tool probe location is fixed in machine coordinate terms it's natural to use that system). This is illegal, it turns out. G53 can only be used with G0 and G1. The problem was that I was in the G59.3 WCS, but after the error G54 had been made the active WCS. Naturally, being in a different WCS than you think you are is disconcerting. I also tried this with G55 in case the G59.3 is special, but same result, G54 set after the error.
In my case, no big deal as I plan to use the G59.3 WCS for tool probing. As an aside, it might be a nice feature if G38 can be used with G53, as tool probes tend to be fixed to the machine - though obviously not part probes. The change of WCS is the main issue. G54 et al are supposed to be modal, but G53 is not, so it looks like a bug to me.
Any comments?
G53 G38.2 Z-10
Any comments?
18 Sep 2020 17:33 - 18 Sep 2020 19:04 #182668
by MaHa
Replied by MaHa on topic G53 and G54
You can set G59.3 to machine zeroNow its the same as using G53, with the benefit of only have to select G59.3 before probing.
It is normal, the machine falls back to G54 after reset or error.
I just remembered this, if using axis 2.8. My reply to subtract 1 is for 2.7.15
forum.linuxcnc.org/21-axis/38824-yes-yes...axis?start=10#164092
This copied from the manual:
3.1. Default Coordinate System
One other variable in the VAR file becomes important when we think about offset systems. This variable is named 5220. In the default files its value is set to 1.00000. This means that when the LinuxCNC starts up it should use the first coordinate system as its default. If you set this to 9.00000 it would use the ninth offset system as its default for start up and reset. Any value other than an integer (decimal really) between 1 and 9, or a missing 5220 variable will cause the LinuxCNC to revert to the default value of 1.00000 on start up.
G10 L2 P9 X0 Y0 Z0
Warning: Spoiler!
Last edit: 18 Sep 2020 19:04 by MaHa. Reason: I did it again: L2 - L20 reversed
18 Sep 2020 20:22 #182678
by nf1z
Replied by nf1z on topic G53 and G54
Thanks for the response. Using G59.3 is exactly what I plan to do in my remapping of M6 - the documentation for G10 L11 is a huge hint! I plan to set up the G59.3 origin at the tool probe trigger point rather than home, so that tool lengths will bear some relation to the actual physical stick out from the spindle. However, the tool probe is a fixed part of the machine, so a G53 move might be considered more appropriate. Hence my test.
Back to the point at issue. You're saying that the error causes the current WCS to become G54 (#5220 is set to 1). Your quote doesn't actually back this up. It only says that if #5220 is not between 1 and 9, a 1 is written (G54). It doesn't say what happens on error. I did a couple of other tests with deliberate errors, and they also changed to G54. It then occurred to me that I had just added an ON_ABORT_COMMAND subroutine, and that includes a G54 block. Removing that causes the G53 error NOT to change the WCS, so this wound is self-inflicted. Not only is it neither a bug nor a feature, it doesn't actually happen.
My apologies to the community - still learning!
19 Sep 2020 18:43 #182774
by bruno2626
Replied by bruno2626 on topic G53 and G54
Hi nf1z,
I noticed the same behavior after an error (for which I will have to open another post). I haven't seen "ON_ABORT_COMMAND" anywhere. How did you remove it?
Thanks.
Thanks.
19 Sep 2020 22:04 #182789
by nf1z
There are many mentions of it, but this might be the main one:
linuxcnc.org/docs/devel/html/remap/remap.html
Section 5.8 talks about it.
Basically, you are supposed to provide a subroutine to provide what you think you need to handle an abort for your situation. I just used the example in the docs without thinking about it, hence my problem. AFAIK, the default is no subroutine, but if you find a line in your .ini file like this
[RS274NGC]
you should look and see what the <on-abort> subroutine is doing. You can remove it by removing the .ini file line (or commenting it out). Or you can edit the subroutine code to do what you really want.
[RS274NGC]
20 Sep 2020 04:43 #182817
by bruno2626
Thanks nf1z,
it's not during a tool change that I have errors. I don't have ON_ABORT_COMMAND in my ini file, but I modified the on_abort file by removing the g54.
I will try again to see if this problem is solved.
Bruno
Bruno
Time to create page: 0.197 seconds
