G96 CSS turn off?
- sharpshooterser
22 Sep 2020 08:43 #183264
by sharpshooterser
G96 CSS turn off? was created by sharpshooterser
I did a bit of a research but havent found a solution for it. On my lathe I use a puller to get the stock out, which requires that spindle is not in motion. Now since I programmed the G96, once the puller gets into the pre position in G0 motion, and code gets to G1 line, it stops.
I cant use G1, its too fast.
How to disable G96?(G97 doesnt work)
22 Sep 2020 10:50 #183269
by AlekseySP
Replied by AlekseySP on topic G96 CSS turn off?
Use G94 before G1
The following user(s) said Thank You: sharpshooterser
- sharpshooterser
22 Sep 2020 11:07 #183271
by sharpshooterser
Replied by sharpshooterser on topic G96 CSS turn off?
I did, but still no luck. Only thing I havent tried is to run the puller on the beginning of the program.
22 Sep 2020 11:46 #183281
by AlekseySP
Your problem has nothing to do with css. You using G95 for feedrate, which is units/revolution.
No revolution - no feed. U have to switch to G94, units/minute. And use appropriate feedrate, like F200 (mm/min) or F10 (in/min). Don't forget to switch back to G95 after or it will be a problem
- sharpshooterser
22 Sep 2020 12:26 #183293
by sharpshooterser
I did use g94, but no luck.
What is interesting - if I add g97 m4 s0 to the program, save it, run it (it still doesnt pull) then delete the g97 m4 s0 and save it again, then it pulls
- sharpshooterser
22 Sep 2020 13:38 #183300
by sharpshooterser
I ll upload the code a bit later
- sharpshooterser
22 Sep 2020 15:13 - 22 Sep 2020 15:15 #183315
by sharpshooterser
here is the program, I tried with g97 included etc. but nothing works.
when it gets to the last part, with T3, after G0 X21 it stops.
Last edit: 22 Sep 2020 15:15 by sharpshooterser.
23 Sep 2020 00:27 - 23 Sep 2020 00:29 #183361
by AlekseySP
I don't see anything wrong in your program, try to get reed of unnecessary words like G99 and put G94 in front of G1
G0 T3M6G43
(IZVLACENJE)
G0 G54
G0 X30 Z2
G0 Z-30
G0 X21
G94 G1 X0 Z-30 F400
M125
G1 X0 Z-4.9 F600
M126
G1 X21 Z-4.9 F400
G0 X30 Z2
G0 T3M6G43
(IZVLACENJE)
G0 G54
G0 X30 Z2
G0 Z-30
G0 X21
G94 G1 X0 Z-30 F400
M125
G1 X0 Z-4.9 F600
M126
G1 X21 Z-4.9 F400
G0 X30 Z2
Last edit: 23 Sep 2020 00:29 by AlekseySP.
- sharpshooterser
23 Sep 2020 15:52 #183486
by sharpshooterser
tried it as well, no luck.
15 Mar 2024 20:45 #295995
by lawley
Replied by lawley on topic G96 CSS turn off?
Good day, did you ever get this resolved?
Time to create page: 0.168 seconds
