The mill just stops!
22 Sep 2020 15:49 #183317
by Robban
The mill just stops! was created by Robban
Hi, trying to run this codeon my mill.
(CG3000 TOP)
(MACHINE)
( VENDOR MEEC MILL)
( DESCRIPTION MEEC MILL)
(T1 D=6. CR=0. - ZMIN=-40. - FLAT END MILL)
N10 G90 G94 G17 G91.1
N15 G21
N20 G53 G0 Z0.
(POCKET1)
N25 T1 M6
N30 S24000 M3
N35 G54
N40 M8
N45 G0 X2.223 Y-155.275
N50 G43 Z10.0 H1
N55 G0 Z6.0
N60 G1 Z5.841 F800
N65 X2.207 Y-155.273 Z5.703 F1200
N70 X2.16 Y-155.268 Z5.572
N75 X2.084 Y-155.26 Z5.455
N80 X1.983 Y-155.254 Z5.36
N85 X1.862 Y-155.251 Z5.29
N90 X1.729 Y-155.253 Z5.25
N95 G3 X1.973 Y-160.948 Z3.671 I0.122 J-2.847
N100 X1.729 Y-155.253 Z2.092 I-0.122 J2.847
N105 X1.973 Y-160.948 Z0.514 I0.122 J-2.847
N110 X1.729 Y-155.253 Z-1.065 I-0.122 J2.847
N115 X1.973 Y-160.948 Z-2.644 I0.122 J-2.847
N120 X1.729 Y-155.253 Z-4.223 I-0.122 J2.847
N125 X-0.999 Y-158.155 Z-5. I0.122 J-2.847
N130 G1 X-0.746 Y-171.335 F1700
N135 X-0.165 Y-185.81
But it just stops at line 55, the code runs fine on my other mill that runs 2.7.14
This mill runs 2.8.0
(CG3000 TOP)
(MACHINE)
( VENDOR MEEC MILL)
N15 G21
N20 G53 G0 Z0.
(POCKET1)
N25 T1 M6
N30 S24000 M3
N35 G54
N40 M8
N50 G43 Z10.0 H1
N55 G0 Z6.0
N60 G1 Z5.841 F800
22 Sep 2020 17:58 #183327
by Hakan
Replied by Hakan on topic The mill just stops!
I would say it is waiting for a "spindle at speed" signal before doing the first G1 move.
22 Sep 2020 21:00 #183345
by Robban
Replied by Robban on topic The mill just stops!
Thanks for the tip!
It might be so, but why does it run the linuxcnc text startup code without problems.
Will check if i get a spindle at speed signal tomorrow.
23 Sep 2020 02:38 #183377
by OT-CNC
Replied by OT-CNC on topic The mill just stops!
My mill usually rapids to position then waits for the spindle at speed to come true. If not, it just sits there. Confused me the first time that happened.
Time to create page: 0.069 seconds
