M19 orient help
20 Oct 2020 16:07 - 20 Oct 2020 16:26 #186704
by COlger81
M19 orient help was created by COlger81
Is there a M19 orientation guru that can help me out. This is the last piece of the puzzle to run lights out on my converted Fadal 3016L. I have come close a couple of times but still have yet to get M19 working. I do have the diagram that somebody posted but i'm still struggling with implementation.
Last edit: 20 Oct 2020 16:26 by COlger81.
20 Oct 2020 16:15 #186707
by COlger81
Replied by COlger81 on topic M19 orient help
Also, i'm using a Hitachi WJ200 VFD.
20 Oct 2020 17:50 #186716
by Henk
Replied by Henk on topic M19 orient help
I have done it on one machine a couple of years ago.
I would suggest that you first check if the drive is capable of controlling the spindle at slow speeds reliably down to 0 rpm and that it can hold that position with reasonable torque if there is no mechanical brake or lock.
The one I did was an old DC spindle drive that can react like a servo for orientation, still relying on orient and pid comps from LCNC
20 Oct 2020 19:02 #186727
by COlger81
The best it's going to do is about 1 hz, which is 30 rpm. It does have a mechanical lock.
21 Oct 2020 05:36 #186789
by Henk
I dont think orient component will help you in this case. Can you tell us more about the sensors on your spindle and how the mechanical lock works?
Is the lock a plunger that enters a groove on the spindle, Is there a proxy or a limit that detects when the plunger has entered the groove?
Sometimes there is a proxy that signals when the plunger is close to the groove? this could be detected by spindle encoder as well though
Time to create page: 0.233 seconds
