Cut compensation problem
- papagno-source
21 Nov 2020 18:15 #189998
by papagno-source
Cut compensation problem was created by papagno-source
Hi i want execute a program for create a DB9 connector panel .
have create this simple program for increase Z axis for 5 mm, but tool path have error because ?
The segment line x9 is again compensated with g42.1 d 3 , but is execute without compensation.
because ?
g61
#1 =0
m3 s1000
g0 z50
x0y0
g1 z0 f1000
o100 repeat[5]
#1=[#1-1]
g42.1 d3 g1 x9 y4.5
x7.5 y-4.5
x-7.5
x-9y4.5
x9 (errror position)
g40 x0y0
g1 z#1
o100 endrepeat
m30
because ?
g61
#1 =0
m3 s1000
g0 z50
x0y0
g1 z0 f1000
o100 repeat[5]
#1=[#1-1]
g42.1 d3 g1 x9 y4.5
x7.5 y-4.5
x-7.5
x-9y4.5
g40 x0y0
g1 z#1
o100 endrepeat
m30
21 Nov 2020 19:52 #190003
by MaHa
Replied by MaHa on topic Cut compensation problem
Cutter compensation is always good for unpredictable problems, that's why i avoid it normally. If the lead in/out is done in the middle of the top line, it could work
g42.1 d3 g1 x-3 y4.5
x9
x7.5 y-4.5
x-7.5
x-9y4.5
x0 (errror position)
g40 x0y0
Time to create page: 0.123 seconds
