G code Generators
30 May 2021 13:47 #210675
by BigJohnT
G code Generators was created by BigJohnT
Around December 2007 I started writing the Simple G code Generators in Python and Tkinter. I'm re-writing them with Python 3 and PyQt5. I have the facing routine done AFAIK if anyone would like to test it that would help. There is a deb that will install a menu item in the LinuxCNC menu if it is there, otherwise it goes in Utilities I think.
github.com/jethornton/gcode
JT
JT
- Thank you received: 5972
30 May 2021 15:35 #210686
Replied by tommylight on topic G code Generators
30 May 2021 16:07 - 30 May 2021 16:09 #210689
by BigJohnT
Replied by BigJohnT on topic G code Generators
My guess is units and a proper preamble... and cut depth and step depth are not negative but if it makes more sense they could be...
Thanks for testing.
Edit: gnipsel.com/linuxcnc/gcode/face.html
JT
Thanks for testing.
JT
Last edit: 30 May 2021 16:09 by BigJohnT.
30 May 2021 16:11 #210690
by BigJohnT
And it looks like I'd be better off using Python decimal numbers instead of floats.
JT
JT
30 May 2021 17:03 #210697
Milling uses negative values for everything Z under the top of the material that is 0, and positive for above the material top and safe height and rapid moves.
30 May 2021 17:21 #210702
by BigJohnT
Ok, I'll change that. I added units to the first page and uploaded a new deb.
Thanks again for testing and input.
JT
JT
31 May 2021 12:13 #210792
by BigJohnT
You can save the settings now and I've fixed the precision to 4 places.
JT
JT
31 May 2021 13:59 #210798
by BigJohnT
What type of path should a pocket routine use? Just G1 or an arc in the corners?
JT
JT
31 May 2021 17:09 #210806
The following user(s) said Thank You: BigJohnT
04 Jun 2021 12:47 #211153
by BigJohnT
Time to create page: 0.234 seconds
