M70 and G64
29 Jun 2021 16:28 #213247
by rajewski
M70 and G64 was created by rajewski
I created a custom tool change macro that overrides M6 and in it I set G61 to ensure there won't be any collisions. I want the tool change to restore the path control mode once it is done so I used M70. According to the docs, it saves "path control mode (G61, G61.1, G64)"
I see that the mode is correctly switched from G61 back to G64 when the tool change happens. However, I don't think it is restoring the "P" value for G64. I set G64 P0.1 (mm) at the start of my gcode but I saw some huge curves (2+mm) after the tool change. It looks like it is just doing G64 with no P value.
Basically my same question was asked a few years back hereĀ forum.linuxcnc.org/40-subroutines-and-ng...re-path-control-mode
Is M70 supposed to restore the tolerance for G64? If not, is there a way to save/restore whatever it was? Do I need to edit my post processor to issue a G64 after each tool change?
29 Jun 2021 18:42 #213257
Replied by andypugh on topic M70 and G64
It looks like the P number should be saved and restored:
github.com/LinuxCNC/linuxcnc/blob/master...erp_convert.cc#L2836
Though the code is not there in 2.8:
github.com/LinuxCNC/linuxcnc/blob/2.8/sr...erp_convert.cc#L2706
So, it looks like the answer is "it works in master, but not in 2.8"
Are you able to use Master, or do you need a workaround for 2.8?
29 Jun 2021 20:31 #213264
by rajewski
Replied by rajewski on topic M70 and G64
Excellent to know this was fixed! I just upgraded to master and can confirm it is behaving as expected. I'll just have to live on the edge for now.
Time to create page: 0.460 seconds
