Last move of macro doesn't run
01 Nov 2021 09:08 - 01 Nov 2021 09:14 #224858
by furynick
Last move of macro doesn't run was created by furynick
I tried a small macro to initialize a probe on my LinuxCNC 2.8.2, the last move of the macro isn't run (G0 Z0), Z axis stay at the position of G38.4.
O<probe_init> SUB
#5000 = 0.0
(PRINT,Probe init)
G90
G49
O100 IF [ #<_hal[tool-number]> NE 99 ]
(PRINT,Go to tool change position )
G53 G0 Z[#<_ini[CHANGE_POSITION]Z>]
G53 G0 X[#<_ini[CHANGE_POSITION]X>] Y[#<_ini[CHANGE_POSITION]Y>]
T99 M6
(PRINT,Tool changed, go to tool setter at X#<_ini[TOOLSENSOR]X> Y#<_ini[TOOLSENSOR]Y>;)
O100 ENDIF
G53 G0 Z[#<_ini[TOOLSENSOR]Z>]
G53 G0 X[#<_ini[TOOLSENSOR]X>] Y[#<_ini[TOOLSENSOR]Y>]
G38.2 Z[#<_ini[AXIS_Z]MIN_LIMIT>] F100
G91
G38.4 Z3 F15
G90
(PRINT,Initial tool height: #5063)
M2
Is there anything I have to add at the end of the macro to "flush" pending commands ?
Last edit: 01 Nov 2021 09:14 by furynick.
01 Nov 2021 09:26 #224861
by furynick
Replied by furynick on topic Last move of macro doesn't run
Forget it, I forgot ENDSUB !
Time to create page: 0.126 seconds
