Small spindle crashed (SOLVED)
05 Nov 2021 15:55 - 05 Nov 2021 15:56 #225406
by PhilipME
Replied by PhilipME on topic Small spindle crashed
I did not try to leave those entries blank in the cam.
But I am assuming that a safe height is necessary for the machine to move to the cutting location.
What I could do is replace G0 entries with G01 (in the G-code file) that is related to Z axis prior to executing the G-code
Last edit: 05 Nov 2021 15:56 by PhilipME.
05 Nov 2021 21:26 #225430
Replied by rodw on topic Small spindle crashed
On uptravel, you are fighting gravity. Excluding gravity and cutting forces, the motor works hardest when accelerating. Once at speed, torque requirement is < 20% of that.
Try reducing your acceleration and increasing your motor voltage if its < 48 volts
The following user(s) said Thank You: PhilipME
Time to create page: 0.083 seconds
