- GCode and Part Programs
- G&M Codes
- User M-code M100-199 not executed but terminated with on_abort_command
24 Nov 2021 20:21 - 24 Nov 2021 20:26 #227528
by alkabal
Hi
I have some trouble trying to use user M-code
I have configured the path :
[RS274NGC]
USER_M_PATH = ./nc_subroutines/remap
Create a file without extension M160 (and do sudo chmod +x M160)
Inside the file :
#!/bin/bash
# file to clear axis info
halcmd setp axisui.notifications-clear 0
sleep .200
halcmd setp axisui.notifications-clear 1
sleep .200
exit 0
Also trying :
#!/bin/bash
echo
echo "Example for User M code invocation:"
echo "M code File"
halcmd setp and2.combined-probe.in1 0
exit 0
The only things i get is the result to
[RS274NGC]
ON_ABORT_COMMAND=<backup_restore> call
I haven't any error message displayed from terminal.
Trying to call some inexistant Mcode return error Mcode unknow.
I use freshly compiled 2.82 run in place rpi4 raspibian x64
[RS274NGC]
Inside the file :
#!/bin/bash
sleep .200
sleep .200
exit 0
Also trying :
#!/bin/bash
echo
echo "M code File"
exit 0
[RS274NGC]
Last edit: 24 Nov 2021 20:26 by alkabal.
25 Nov 2021 00:58 #227549
by chen1234
Replied by chen1234 on topic User M-code M100-199 not executed but terminated with on_abort_command
I think the user-defined code (M100-M199) only needs to be in the .../linuxcnc../nc_files/ directory so that it can be recognized by Linuxncnc (I have encountered it before, this is just my solution,http://linuxcnc.org/docs/2.8/html/config/ini-config.html#sec:display-section)
25 Nov 2021 01:15 #227551
by alkabal
Replied by alkabal on topic User M-code M100-199 not executed but terminated with on_abort_command
Thanks a lot for reply
I will have see your topic and try your solution without success
Test done with and without specified USER_M_PATH =
Imo the file are correctly found because i have a error message trying to use inexistant Mcode
I don't understand
#!/bin/bash
echo
echo "M code File"
exit 0
the only result i get is the ON_ABORT_COMMAND
I don't understand
#!/bin/bash
echo
echo "M code File"
exit 0
26 Nov 2021 01:16 #227602
by alkabal
Problem solved with : changing the Character Coding from CR+LF to LF
- G&M Codes
