Dwell after M3
02 Dec 2021 17:19 #228204
by _big_
Dwell after M3 was created by _big_
Takes a few seconds for my quill to spin up after M3/M4.
Could probably monkey with the VFD and make it better, but it generally seems to me I should be able to specify some delay after commanding a speed change to the spindle.
Tried to add a G4 through CamBam, but couldn't get that to work right.
Then I thought, generally, machine specific delays shouldn't be specified from the CAM program. This delay should really be part of the machine controller.
I looked a bit and couldn't find anything in LinuxCNC. My guess its there and I missed it. Anybody have some clues for me??
Thanks.
Thanks.
- shortcircuit48
- Thank you received: 3
02 Dec 2021 17:43 #228208
by shortcircuit48
Replied by shortcircuit48 on topic Dwell after M3
G4 P5 gives a 5sec delay, and works for me.
02 Dec 2021 18:22 #228212
by _big_
Replied by _big_ on topic Dwell after M3
I could easily do that if I were editing the G code by hand.
I desire to take the output of CamBam and use it without editing.
In CamBam, is if I go into the machine postprocessor and add G4 P5 to the G3 definition, CamBam produces something like
G3
G4 P5
S1000
Which I don't think will do what I desire. Tried this several different ways and couldn't get the S1000 before the G4 P5. But maybe it will? I haven't tried it on the machine.
G3
G4 P5
S1000
The following user(s) said Thank You: shortcircuit48
02 Dec 2021 18:37 #228213
by chris@cnc
Replied by chris@cnc on topic Dwell after M3
If you send your postprocessor i can take a look. Second option, setup spindle ramp in hal. But edit the PP should be easier.
02 Dec 2021 19:00 #228216
by _big_
I'm using the nominal LinuxCNC.cbpp. It's not very big and I'll just append the text to the end of this.
In this LinuxCNC.cbpp, there is no definition for G3. I guess CamBam picks it up from some default.
<?xml version="1.0" encoding="utf-8"?>
<PostProcessor xmlns:xsi="www.w3.org/2001/XMLSchema-instance" xmlns:xsd="www.w3.org/2001/XMLSchema" Version="0.9.8.0">
<PostFile>{$comment} Made using CamBam - www.cambam.co.uk {$endcomment}
{$header}
{$mops}
{$footer}
</PostFile>
<Header>{$comment} {$cbfile.name} {$date} {$endcomment}
{$comment} Post processor: LinuxCNC {$endcomment}
{$tooltable}
{$cbfile.header}
{$units} {$distancemode} {$velocitymode} {$cuttercomp(off)}
{$arccentermode}
{$toolchange(first)}
{$clearance}</Header>
<Footer>{$clearance}
{$spindle(off)}
{$cbfile.footer}
{$endrewind}
</Footer>
<MOP>{$comment} {$mop.name} {$endcomment}
{$toolchange}
{$velocitymode} {$workplane}
{$mop.header}
{$spindle} {$s}
{$blocks}
{$mop.footer}
</MOP>
<Drill>{$g81} {$_x} {$_y} {$_z} {$r} {$_f}</Drill>
<DrillDwell>{$g82} {$_x} {$_y} {$_z} {$p} {$r} {$_f}</DrillDwell>
<DrillPeck>{$g83} {$_x} {$_y} {$_z} {$q} {$r} {$_f}</DrillPeck>
<NumberFormat>0.0####</NumberFormat>
<MinimumArcLength>0.0001</MinimumArcLength>
<ArcCenterIncremental>G91.1</ArcCenterIncremental>
<ArcCenterAbsolute>G90.1</ArcCenterAbsolute>
</PostProcessor>
{$header}
{$mops}
{$footer}
</PostFile>
{$tooltable}
{$cbfile.header}
{$arccentermode}
{$spindle(off)}
{$cbfile.footer}
{$endrewind}
</Footer>
{$toolchange}
{$mop.header}
{$spindle} {$s}
{$blocks}
{$mop.footer}
</MOP>
</PostProcessor>
02 Dec 2021 20:01 #228220
This is what "spindle-at-speed" is for. It will allow G0 moves once the spindle is started, but will pause the first g1 move until the spindle-at-speed pin is set to true.
You can get this signal either from the VFD, or from the spindle encoder. Or, with a bit of HAL, you can fake it with a simple delay triggered by spindle-on.
linuxcnc.org/docs/2.8/html/man/man9/moti....html#SPINDLE%20PINS
Replied by andypugh on topic Dwell after M3
02 Dec 2021 20:16 #228221
by chris@cnc
I found something here
cambamcnc.com/forum/index.php?PHPSESSID=...18q6s31&topic=9266.0
There should some menu to enter G4 P5 and in PP line "{$spindle} {$s}" delete "{$s}"
But this kind of PP i see first time.
02 Dec 2021 20:45 - 02 Dec 2021 20:47 #228222
by chris@cnc
for Andy's suggestion, here are some examples.
linuxcnc.org/docs/html/examples/spindle.html
Last edit: 02 Dec 2021 20:47 by chris@cnc.
Time to create page: 0.099 seconds
