Manual tool change confusion
09 Dec 2021 16:37 - 09 Dec 2021 16:38 #228713
by _big_
Manual tool change confusion was created by _big_
If I touch off tool 1 and then tool 2, I see the compensations in the tool table. And after touching off tool 2, TLO Z: appears to be what I expect.
If I then T1 G6, and confirm the tool change, the correct offset for tool 1 shows up at the bottom of the Axis window, but TLO Z: does not update with the offset for T1. If I utter G43 in the command window, TL0 Z: updates with tool 1 offset.
During this whole period G43 is showing the modal window.
To my way of thinking, when G43 is active, a tool change should automatically update the TLO Z:.
I could probably convince the CAM program to issues a G43 after every tool change, but that doesn't seem right to me.
Thanks for any clues.
Last edit: 09 Dec 2021 16:38 by _big_.
- Thank you received: 1369
09 Dec 2021 17:06 #228717
Replied by Todd Zuercher on topic Manual tool change confusion
I have not used Linuxcnc on a tool changing machine, but it is normal on other machine controls I've used to require reissuing the G43 command to for a new tool offset to be applied.
The following user(s) said Thank You: _big_
Time to create page: 0.075 seconds
