python M-CODE to write active program on a file
06 Apr 2022 15:57 #239450
by ioiotutu
python M-CODE to write active program on a file was created by ioiotutu
i try to write the active program name on a file with M190 code inside g-code program. For this i created M190 file:
************************************ M190 code
#!/usr/bin/env python
import sys
import hal
import linuxcnc
import time
try:
s = linuxcnc.stat() # create a connection to the status channel
s.poll() # get current values
except linuxcnc.error, detail:
print "error", detail
sys.exit(1)
x=s.file.split("/")
prg_file=open('/home/max/test', 'a')
prg_file.write(time.strftime("%Y/%m/%d")+','+ time.strftime("%H:%M:%S") +','+ x[len(x)-1] '+'\n')
prg_file.close()
*********************************** end M190 code
G-Code name file example test.ngc:
G90
G0X0Y0
M190
M2
All work fine, into the file test there is "test.ngc" string with date and time.
I have a problem if inside the g-code file there is a tool change call (M6T1).
I have remapped M6 code to a soubroutine "change.ngc" that run on M6Txx call and after M190 call i find into the file the string "change.ngc" instead of "test.ngc".
Probably python code "s.file" read the last called soubroutine !
Is there a way to read active program from axis interface?
I would do a logfile where inside there is g-code program name+date+time to count program worked in a day.
Thanks,
Michele
import sys
import hal
import linuxcnc
import time
try:
sys.exit(1)
x=s.file.split("/")
prg_file.close()
G90
G0X0Y0
M190
M2
Thanks,
Michele
07 Apr 2022 00:26 #239485
by cakeslob
This is what im using to get the currently loaded file in axis. Im not sure if it will do the same thing with a remap
Replied by cakeslob on topic python M-CODE to write active program on a file
os.path.basename(loaded_file)
07 Apr 2022 06:56 #239511
by ioiotutu
Replied by ioiotutu on topic python M-CODE to write active program on a file
os.path.basename(loaded_file) method return the tail of path of "loaded_file".
If loaded_file="/home/max/aaa.ngc"
os.path.basename(loaded_file) return "aaa.ngc"
How to assign loaded_file ?
Thanks.
Thanks.
