Remapped M code in python mdi command
21 Jul 2022 13:53 #247941
by AndrewL
Remapped M code in python mdi command was created by AndrewL
I have a remapped M code written in python. I'm having trouble with the parts of the code using linuxcnc.command() - the M-Code will work when run from the mdi, but not when it is inside another .ngc program.
Example error messages:
can't do that (EMC_TOOL_LOAD_TOOL_TABLE) in auto mode with interpreter waiting
can't do that (EMC_TASK_PLAN_EXECUTE) in auto mode with interpreter reading
Must be in MDI mode to issue MDI command
The main question I have is:
Is there a workaround for executing a motion command (eg. G0 Z0) from #!/usr/bin/python code?
Here is a simplified remapped M-Code that is condensed down to the problematic sections:
(Note: On other code, I tried omitting #!/usr/bin/python and let python do: print(G0 Z0) to linuxcnc but then there is a tkinter import problem:
import-im6.q16: attempt to perform an operation that is not allowed by the security policy 'PS' @ error/constitute.c/IsCoderAuthorized/408.)
#!/usr/bin/python
import linuxcnc
s = linuxcnc.stat()
c = linuxcnc.command()
#Problem Command (solved):
# c.set_digital_output(16,1)
#Error Message: can't do that (EMC_MOTION_SET_DOUT) in auto mode with the interpreter waiting
#Solution: use shell command
#Problem Command:
linuxcnc.command().load_tool_table()
# can't do that (EMC_TOOL_LOAD_TOOL_TABLE) in auto mode with interpreter waiting
#Problem Command:
# c.mdi("M127")
carouselZ = -1.3192
c.mdi('G53 G90 G0 Z{}'.format(carouselZ))
# Must be in MDI mode to issue MDI command
exit(0)
21 Jul 2022 19:41 #247983
Replied by andypugh on topic Remapped M code in python mdi command
If you are in a _remap_ and want to move an axis then use canonical commands.
import emccanon
There is an example in the testsuite:
github.com/LinuxCNC/linuxcnc/blob/2e75b0...terp/pymove/oword.py
I think you would need to look through emccanon.cc to find the list of canonical commands
import emccanon
26 Jul 2022 17:28 #248353
by AndrewL
Replied by AndrewL on topic Remapped M code in python mdi command
Thank you for your reply.
I can get this code to work inside test.ngc. But how do you execute it from python?
for example:
m159
... fails with:
File "./nc_files//M159", line 11, in <module>
oword = imp.load_source('oword', './python/oword.py')
File "./python/oword.py", line 21, in <module>
from util import call_pydevd
ImportError: No module named util
is_callable(oword.on_abort) = FALSE
for example:
m159
#!/usr/bin/python
print('m159 test')
import sys
sys.path.append('./python/oword.py')
import imp
oword.canonmove(X1, Y3, Z0)
exit(0)
... fails with:
31 Jul 2022 10:01 #248711
You probably can’t run it outside of a remap routine. It needs to run in the context of an active interpreter.
17 Aug 2022 15:39 #249952
by AndrewL
I have solutions for most of these problems
Error Messages:
My solution:
create M-code M150:
M150 can be called from another M code:
If the execution order gets problematic, I use
delayed_machine_command inside python a M code
M504 in a .ngc to make sure it gets executed at the right time
Error Messages:
My solution:
create M-code M150:
#!/usr/bin/python
# call shell script from the python script
print('___________________start M150___________________')
import os
import subprocess
import time
import math
def write_hal_signal(hal_signal , value):
command = ['halcmd','sets',hal_signal,str(value)]
process = subprocess.Popen(command, stdout=subprocess.PIPE, stderr=None)
output = process.communicate() #Launch the shell command
# print 'output:',output[0]
# print 'outputF:', output
# print 'poll', process.poll()
if process.poll() == 0:
# print(command, 'success')
return 'success'
else:
print(command, 'failure')
return 'failure'
def write_hal_pin(hal_pin , value):
command = ['halcmd','setp',hal_pin,str(value)]
return 'success'
else:
return 'failure'
def read_hal_signal(hal_signal):
command = ['halcmd','gets',hal_signal]
(command_output, error) = process.communicate() #Launch the shell command
value_str = str.strip(command_output)
if value_str == 'FALSE':
value = 0
elif value_str == 'TRUE':
value = 1
else:
try:
value = float(value_str)
except:
value = None
# print 'Vaue Error!'
# print 'value: ', value
else:
value = None
return value
def read_hal_pin(hal_pin):
command = ['halcmd','getp',hal_pin]
value = 0
value = 1
else:
try:
except:
value = None
else:
value = None
return value
def wait_hal_signal(hal_signal, value):
# import time
if read_hal_signal(hal_signal) is None:
wait_success = 0
else:
while read_hal_signal(hal_signal) != value:
wait_success = 0
time.sleep(0.1)
print 'Waiting for {}: {} == {}'.format(hal_signal, read_hal_signal(hal_signal),value)
print 'wait_success'
wait_success = 1
return wait_success
def machine_command(*command_string): #executes G-code / M-code machine commands # can't take debug commands
start_time = time.time()
print('>>>>>>>>>>>>>>> execute g-code: ', command_string)
'''Edit the subroutine .ngc file used by the halui.mdi-command'''
writeMode = "w"
a_file = open("./nc_subroutines/m502.ngc", writeMode) #write mode
writeMode = "a"
remap_header = '''
; this file is auto-generated by python code in M150
; argspec Values are set by shell script via python (eg. M150)
; include these in the .ini file:
; [RS274NGC]
; REMAP=M502 modalgroup=10 argspec=(none) ngc=m502
; [HALUI]
; MDI_COMMAND = M502 (halui.mdi-command-02: machine_command_trigger)
o<m502> sub
# print remap_header.splitlines()
remap_header_list = remap_header.splitlines()
for line in remap_header_list:
a_file.writelines(line)
a_file.writelines('\n')
for command in command_string:
a_file.writelines(command)
# a_file.writelines('\n')
# a_file.writelines('(DEBUG, exectued m502: {})'.format(command))
remap_footer = '''
o<m502> endsub
M2
remap_footer_list = remap_footer.splitlines()
for line in remap_footer_list:
a_file.close()
''' execute the halui.mdi-command '''
write_hal_signal('machine_command_trigger',1)
time.sleep(0.1) #pulse signal time
write_hal_signal('machine_command_trigger',0)
print("--- %s seconds ---" % (time.time() - start_time))
def delayed_machine_command(*command_string): #executes G-code / M-code machine commands
writeMode = "w"
a_file = open("./nc_subroutines/m504.ngc", writeMode) #write mode
writeMode = "a"
remap_header = '''
; this file is auto-generated by python code in M140
; argspec Values are set by shell script via python (eg. M140)
; [RS274NGC]
; REMAP=M504 modalgroup=10 argspec=(none) ngc=m504
; [HALUI]
; MDI_COMMAND = M504 (halui.mdi-command-04: execute_delayed_command)
o<m504> sub
# a_file.writelines('(DEBUG, exectued m504: {})'.format(command))
remap_footer = '''
o<m504> endsub
M2
a_file.close()
# ''' execute the halui.mdi-command '''
# write_hal_signal('machine_command_trigger',1)
# time.sleep(0.1) #pulse signal time
# write_hal_signal('machine_command_trigger',0)
def testprint(*strings):
for string in strings:
print string
def viewPockets():
command = ['/home/weeke1/linuxcnc/configs/Weeke1/nc_files/M118']
return 'openPocketView success'
else:
print(command, 'openPocketView failure')
return 'failure'
def showRotation():
command = ['/home/weeke1/linuxcnc/configs/Weeke1/nc_files/M117']
return 'showRotation success'
else:
print(command, 'showRotation failure')
return 'failure'
# import threading
# def printit():
# threading.Timer(5.0, printit).start()
# #print "Hello, World!"
# print 'Weeke1Logic.0.loadA4State', read_hal_pin('Weeke1Logic.0.loadA4State')
# return read_hal_pin('Weeke1Logic.0.loadA4State')
# from threading import *
# import time
# def thread_1():
# #for i in range(8):
# while True:
# time.sleep(0.1)
# T = Thread(target = thread_1) # creating a thread
# T.setDaemon(True) # change T to daemon
# T.start() # starting of Thread T
# time.sleep(5)
# print('this is Main Thread')
# ''' expand functionality with examples here:
# https://stackoverflow.com/questions/3393612/run-certain-code-every-n-seconds
if __name__ == "__main__":
""" Run test commands here """
# print 'WRITE', write_hal_signal('areaLeftUnlock',1)
# print 'WRITE', write_hal_signal('changeCommand',1)
# print 'READ',read_hal_signal('areaLeftUnlock')
# print 'WAIT', wait_hal_signal('223_Foot_Switch_A4',1)
##### signal's pin to be read by M502
# write_hal_signal('pyPosValueX',23.123)
##### move to enabled axis values via pyPosMoveCmd => halui.mdi-command-02 => M502
# write_hal_signal('pyPosMoveCmd',1)
# time.sleep(1)
# write_hal_signal('pyPosMoveCmd',0)
# g_code_string_cmd('G53 g90 G0 X4 Z-0.125')
# g_code_string_cmd('G53 G1 X20 F100')
# g_code_string_cmd('X4 Z-0.125')
# machine_command('G53 G0 X10 Y-5')
# machine_command('G53 G0 X10 Y-5','G53 G0 X20 Y-10')
#can't do this# machine_command('(DEBUG, M150 machine_command)')
# machine_command('M127')
# write_hal_signal('testMoveCmd',1)
# time.sleep(1)
# write_hal_signal('testMoveCmd',0)
# write_hal_signal('m140active',0)
# write_hal_signal('router1CylPosMuxIn1',0)
# printit()
# machine_command("G58 G91 G2 X0 Y0 I0.0001 P1 F150","G90")
# machine_command("M550 P1 Q2")
# openPocketView()
print ("M150 is being run directly")
print ("M150 __name__ = %s" %__name__)
print('___________________end M150___________________')
exit(0) # If a M1nn command exits with nonzero status, the gcode program exits. Exit 0 for success
else:
print ("M150 is being imported")
""" M150 import """
# import sys
sys.path.append('/path_to_file/nc_files/M151')
import imp
M150 = imp.load_source('M150', '/home/weeke1/linuxcnc/configs/Weeke1/nc_files/M150')
from M150 import *
Time to create page: 0.078 seconds
