How to manage a part offset and a local offset
22 Jul 2022 04:21 #248004
by dansawyer
How to manage a part offset and a local offset was created by dansawyer
The project is to machine parts with individual local subroutines. I tried setting the part offset:
g01 x -[#<_offset>] y -[#<_offset>]
g10 l20 p1 x0 y0
and then set a local subroutine relative
g01 x - [#<_int_width> / 2] y -[#<_int_width> - #<_mill_step>]
g10 l20 p1 x0 y0 ; set the relative axis to
The second g10 overwrites the first g10 and the part offset is lost. In this example: \
1. what command should be used to set the origin for the part?
2. what command should be used to set the local subroutine part origin?
3. How can the first, part origin, be cleared?
4. How can the second, subroutine origin, be cleared?
Thanks, Dan
g10 l20 p1 x0 y0
Thanks, Dan
22 Jul 2022 11:44 #248023
Replied by andypugh on topic How to manage a part offset and a local offset
It is fairly common to use G92 for this.
linuxcnc.org/docs/stable/html/gcode/g-code.html#gcode:g92
Move the tool to the part origin.
G92 X0 Y0 Z0
{do machining}
G92.1
G92 X0 Y0 Z0
{do machining}
G92.1
22 Jul 2022 14:01 #248031
by dansawyer
Replied by dansawyer on topic How to manage a part offset and a local offset
Thank you. That woried perfectly. Dan
22 Jul 2022 14:21 #248033
by dansawyer
It would be convinient to call a subroutine within a subroutine and set a local coordinates for that nested call. Assuming the above with g54 working for the first subroutine is there a command that can augment the g54 position for additional subroutine calls?
29 Jul 2022 11:50 #248611
There is G52, but I have never used it:
linuxcnc.org/docs/stable/html/gcode/coordinates.html#sec:g52
You could also experiment with saving and loading the "modal state":
linuxcnc.org/docs/stable/html/gcode/m-code.html#mcode:m70
Time to create page: 0.081 seconds
