Parametric G-Code; take axis name/ID from a variable?
04 Oct 2022 04:53 #253413
by swarren
Parametric G-Code; take axis name/ID from a variable? was created by swarren
I am writing a script to automate touch-off against a probe bar. I have written the same script 3 times; once each for the X, Y, and Z axes. The body of the script is identical in all 3 cases except for the axis name in the G38/G01 commands. Is there any way to use a variable for the axis name, so that I can either (a) use a sub-routine for the body of the script, or (b) make the scripts 100% identical so that it's easier to keep them in sync using "diff" or similar?
My current Z-axis script: github.com/fortcollinscreatorhub/cnc/blo...cnc/nc_files/100.ngc
My current X-axis script: github.com/fortcollinscreatorhub/cnc/blo...cnc/nc_files/103.ngc
My current Y-axis script: github.com/fortcollinscreatorhub/cnc/blo...cnc/nc_files/104.ngc
Some ideas that have been suggested:
a) Include all 3 of X, Y, Z axes in each G38/G01 command, and have separate probe_x/y/z_dir variables (with value -1 or 1 for the desired axis, and 0 for the other 2 axes, which will zero out the movement in unwanted directions). This will work, but will make the script a bit harder to read and understand.
b) Maybe "G10 L2 P0 R90" can be used to rotate between X/Y axes, but I'm not sure, and it won't work for Z.
Ideally, I'd love to do this: "G38.3 #<axis_name>[#<probe_dir> * #<probe_max_distance>] F[#<fast_probe_rate>]". However, variables can apparently only contain numbers, not strings/text:-(
Thanks for any ideas!
04 Oct 2022 21:38 - 04 Oct 2022 21:38 #253471
linuxcnc.org/docs/stable/html/gcode/o-co...ml#ocode:conditional
Replied by andypugh on topic Parametric G-Code; take axis name/ID from a variable?
O100 IF [#<axis> EQ 0]
G38.2 X100 F20
O100 ELSEIF [#<axis> EQ 1]
G38.2 Y100 F20
O100 ELSEIF [#<axis> EQ 2]
G38.2 Z100 F20
O100 ELSEIF [#<axis> EQ 9]
G38.2 W100 F20
O100 ELSE
(ABORT, Something went terribly wrong)
O100 ENDIF
Last edit: 04 Oct 2022 21:38 by andypugh.
05 Oct 2022 00:54 #253481
by swarren
Replied by swarren on topic Parametric G-Code; take axis name/ID from a variable?
That would work, but I'd essentially be replicating the program many times within the if statement. I was hoping for one statement that'd cover all the axes.
I'm thinking of just writing a custom M code in Python, since that allows much more flexible use of variables...
05 Oct 2022 04:11 #253491
by swarren
OK, so I've started to work out how to do this in a Python remap. A couple of questions:
1. linuxcnc.org/docs/stable/html/remap/rema...ming-embedded-python says:
2. How stable is this Python remap feature? Clearly if I write my code in G-Code, it's quite likely to keep working whenever I upgrade LinuxCNC. However, since Python remaps seem like a less commonly used and documented feature, I worry whether using it may cause headaches for some future maintainer of this machine, e.g. if I'm no longer involved in a few years and someone upgrades LinuxCNC, then everything breaks and they have a hard time fixing it if they aren't a programmer.
For the record, here's the very bare skeleton that I've been using to test the feature:
configs/sim/axis/axis.ini:
python/toplevel.py:
python/remap.py:
However, in practice my code is calling self.execute() after yielding, and works fine. Are the docs simply out-of-date, or are there cases where I'll see this randomly break if I'm unlucky?
- Code following a yield may not recursively call the interpreter, like with self.execute("<mdi command>"). This is an architectural restriction of the interpreter and is not fixable without a major redesign.
[PYTHON]
PATH_PREPEND= python
TOPLEVEL= python/toplevel.py
LOG_LEVEL = 8
[RS274NGC]
REMAP= M400 py=fcch_probing
python/toplevel.py:
import remap
python/remap.py:
from interpreter import *
def fcch_probing(self, **words):
try:
self.execute("G91")
self.execute("G38.3 X1 F10")
yield INTERP_EXECUTE_FINISH
self.execute("G0 X-0.25")
self.execute("G38.3 X0.5 F2.5")
self.execute("G0 X-0.5")
except InterpreterException as e:
self.set_errormsg(e.error_message)
return INTERP_ERROR
return INTERP_OK
05 Oct 2022 08:26 #253507
Maybe only the probe moves, it depends on what the rest of the code does. You can pull out the correct probe result bu a computed parameter, for example.That would work, but I'd essentially be replicating the program many times within the if statement.
05 Oct 2022 09:16 #253509
A remap should be as stable as Python, which isn't saying much. I would definitely target Python 3.
06 Oct 2022 05:52 #253592
by swarren
For anyone finding this thread later by Google, an update on the Python approach:
I've found an example of the problems that the documentation describe, where you can't issue and wait for multiple batches of G-Code commands within a Python remap. If I execute the remapped G-Code from the MDI, the code I wrote above works. If I execute the remapped code from 100.ngc which I trigger from an Axis UI button, then I get an error:
So, I guess I'll do this in plain old G-Code.
print(5070, self.params[5070])
# The execute() below works, if M400 executed from the MDI UI
# The execute() below raises the following, if M400 executed from 100.ngc, triggered from an Axis UI button:
# emc/task/emctask.cc 69: interp_error: exception during generator call: Traceback (most recent call last):
Time to create page: 0.080 seconds
