G70 - 'Unkown G -Code used' error in 2.8.4
14 Oct 2022 16:09 #254119
by Hodge
G70 - 'Unkown G -Code used' error in 2.8.4 was created by Hodge
I wanted to try the G70 code after updating to 2.8.4 on my lathe using AXIS GUI.
I'm new to G70 so I wrote the attached program to see how it might work.
However, when I load the program LCNC tells me that there is an unknown G code used for the G70.
Do I need to do anything other than a standard install to get G70 working or am I coding incorrectly??
14 Oct 2022 17:23 #254126
Replied by andypugh on topic G70 - 'Unkown G -Code used' error in 2.8.4
Sorry, but G70 (and friends) are not in 2.8.4.
They are in / will be in 2.9, which can be installed (but be aware that it is a dev version, so might occasionally break)
see buildbot.linuxcnc.org for how to install 2.9.
The following user(s) said Thank You: Hodge
15 Oct 2022 08:56 #254155
by Hodge
Replied by Hodge on topic G70 - 'Unkown G -Code used' error in 2.8.4
Thanks Andy
