msg and parameters
20 Nov 2022 19:10 #257171
by Carsten
msg and parameters was created by Carsten
i can print parameters, e.g.
(print, Probing result: #5061, #5062, #5063).
Can this also be done with "msg"?
(msg, Probing result: #5061, #5062, #5063)
does not work.
Regards
Carsten
does not work.
Regards
Carsten
20 Nov 2022 19:30 - 20 Nov 2022 19:34 #257172
by roland
Replied by roland on topic msg and parameters
try
linuxcnc.org/docs/html/gcode/overview.html#gcode:debug
(debug,Probing result: #5061, #5062, #5063)
Last edit: 20 Nov 2022 19:34 by roland.
20 Nov 2022 19:49 #257173
by Carsten
Replied by Carsten on topic msg and parameters
Works,
thanks
thanks
21 Nov 2022 21:07 #257259
by Carsten
Does'nt fit in the G Code category but similar topic:
Are there any means to send a message/debug from an M100 script,
e.g.
#!/bin/bash
/usr/bin/linuxcnc_msg "Switch ..."
halcmd sets switch_...
exit 0
e.g.
#!/bin/bash
exit 0
22 Nov 2022 23:30 #257400
Replied by andypugh on topic msg and parameters
One way is for your M100 to be a Python script rather than bash.
#!/usr/bin/env python3
import tkinter
from tkinter import messagebox
ret = messagebox._show("Heading",
"Your Message Here",
messagebox.QUESTION,
messagebox.YESNOCANCEL)
Time to create page: 0.226 seconds
