M6 moves spindles down before pausing for change
28 Oct 2023 17:19 #283970
by edmarwjr
M6 moves spindles down before pausing for change was created by edmarwjr
I am new in linuxcnc, in fact in CNC in general.
I have a PM-728 machine, did CNC conversions without problems.
I am using Mesa boards.
Initially used pncconf for general setup.
Now, I am editing the .hal and .ini files to fill some details.
I am stuck trying to setup auto tool measurement in gmoccapy.
I did all the changes posted in the manual (2.8)
Remap of M6 is working, I uncommented the debug statements, and add some more
Problem:
When I perform a tool change, the change.ngc moves the spindle up to the CHANGE_POSITION, as exepected.
Then executes M6.
The machine moves all the way down, to the lower Z limit, almost touching the table.
Then it asks to make a tool change (Which is physically impossible, given the lower position).
I press OK, just to see if there are other problems. The head moves up to TOOLSENSOR position, everything goes normal to end
So, I narrow down the problem to the M6. The description of the command says it should move the head up, not down.
What is happening ?
Any suggestions ?
Problem:
Then executes M6.
What is happening ?
Any suggestions ?
28 Oct 2023 17:35 - 28 Oct 2023 17:35 #283972
Replied by andypugh on topic M6 moves spindles down before pausing for change
Do you have any of TOOL_CHANGE_POSITION, TOOL_CHANGE_AT_G30 or TOOL_CHANGE_QUIIL_UP set in the INI file? This feels like a move during the standard M6 call section.
linuxcnc.org/docs/stable/html/config/ini....html#_emcio_section
Last edit: 28 Oct 2023 17:35 by andypugh.
28 Oct 2023 19:20 #283982
by edmarwjr
Replied by edmarwjr on topic M6 moves spindles down before pausing for change
Yes,
I have TOOL_CHANGE_QUILL_UP = 1
I comment out this line, and the problem is fixed.
Spindle stays at CHANGE_POSITION during M6 execution.
28 Oct 2023 19:36 #283984
That probably means that you have the machine set up with Z = 0 at the bottom. It's best to have Z = 0 at the top, and all other positions negative.
It wouldn't matter, except lots of CAM systems like to insert G53 G0 Z0 in the code, assuming that it is a clear Z move.
I would change it, just in case.
28 Oct 2023 20:39 #283992
by edmarwjr
You can see that I never run any G code. I though that having all coordinates numbers positive would be more intuitive.
Thanks for the insight.
I changed top to zero. Adjusted my tool probe numbers. Everything is OK.
