G96 CSS will not cancel
15 Mar 2024 16:05 #295973
by lawley
G96 CSS will not cancel was created by lawley
Not sure if this has been covered before. If my program issues a G96 command and I later want to use G94 G1 to move to a bar feeder position the machine goes to the G0 pre position and then hangs. I have tried issuing a G97 before the G1 line and on the same line, tried G94 before the G1 and on the same line, No luck.
- Thank you received: 5930
15 Mar 2024 16:48 #295976
Time to create page: 0.076 seconds
