Changing the openGL colors in the Axis GUI
06 Mar 2012 17:39 - 06 Mar 2012 17:40 #18430
by loboy
Replied by loboy on topic Re:Changing the openGL colors in the Axis GUI
Last edit: 06 Mar 2012 17:40 by loboy.
12 Apr 2012 03:21 #19134
by JR1050
Replied by JR1050 on topic how did you change the backround colors
I am floored with the changes you made to the Axis GUI,great job!!!!I would really like to change the backround colors and text colors myself.Can you shed some light on how you did it and how.Ive spent some time looking at the axis and and tcl files and Im kinda lost.I do ok with C,but python is new.Thanks
12 Apr 2012 16:21 #19149
by loboy
Replied by loboy on topic Re:how did you change the backround colors
Hey JR,
First, to change the live plotter preview colors in Axis you have to copy the contents of the file:
(this is where the color values are stored)
into the file:
then you have to merge it using:
You may have to create the .Xresources file if it is not there.
Changing the text colors for the rest of the application is a little more in depth. If you have never programmed in TCL, I would suggest looking at effbot.org/tkinterbook/ . I used it a lot.
The majority of the interface code is found in:
Read over that code. I can give you more specifics where to look if you tell me exactly what you want to change.
/usr/share/doc/emc2/axis_light_background
into the file:
~user/.Xresources
xrdb -merge .Xresources
/usr/share/axis/tcl/axis.tcl
12 Apr 2012 16:42 #19150
by loboy
I should have mentioned that what I suggested above is specifically for changing the Live Plotter Preview colors. If you wish to change the background color for the entire application, this is slightly different. TCL is very much object oriented. There is no C, only Python and TCL.
12 Apr 2012 19:10 #19156
by toplakd
Replied by toplakd on topic Re:how did you change the backround colors
Hi.
Is there ETA on relase date?
Thank you, Dejan
Thank you, Dejan
12 Apr 2012 19:41 #19157
by loboy
I have no plans for a release.
12 Apr 2012 19:44 #19158
by toplakd
To bad.
Because I think it will be a success, even if it was for sale.
Dejan
Dejan
12 Apr 2012 20:09 #19159
by loboy
I really don't know the process of releasing it and I have only tested it on my hardware. Right now I just do not have the time to figure out how to package it correctly for release. I would love to give it back to the community. I also ripped out code I did not need, and wrote some new stuff. I would probably have to fork it.
If you could give me some suggestions as to how to proceed, I will definitely look in to it.
12 Apr 2012 21:33 #19160
by JR1050
Replied by JR1050 on topic Re:Changing the openGL colors in the Axis GUI
Thanks for the response.I would like to change the backround color of the lower box with the g code program in it from white to black and the text to either bright blue or green.I would also like to change the bluish geay back round of the basic gui to blue.
Eventually I would like to put the plot,dro,mdi,manual and tool offsets in their own tab,similar to the way the dro and plot is set up now.It would be similar to the way Fanuc uses soft keys.I have downloaded a couple TKinter tutorials and how to's.The axis file is just plain hard to follow.Thanks for your help.
JR
JR
13 Apr 2012 00:30 #19162
by KPA
Replied by KPA on topic Re:how did you change the backround colors
toplakd wrote:
I agree, you've done a great job modernizing Axis, sort of breathed some life back into it. Not sure of the submission process, I think you need to ask one of the Board of Director types here, they should be able to answer that question.
Jay
To bad.
Dejan
Jay
Time to create page: 0.300 seconds
