Axis Hangup!
27 Feb 2010 15:02 #2089
by eslavko
Axis Hangup! was created by eslavko
Hello...
Here is code that hangup Axis.
Seems that axis dryrun that code and make infiniti loop as #5070 parameter is not updated (probe trigered)
How to overcome that?
G21
G91
F80
o<YSearch> do
G38.3 Y1
o<YSearch> while[#5070 eq 0]
M02
27 Feb 2010 15:19 - 27 Feb 2010 16:09 #2091
by acemi
Replied by acemi on topic Re:Axis Hangup!
Why do you need while loop here?
Last edit: 27 Feb 2010 16:09 by acemi.
27 Feb 2010 15:44 #2092
by eslavko
Replied by eslavko on topic Re:Axis Hangup!
The idea of code is to make move until probe hit object.
As position is not known I just make progres until get hit.
If I want just one move then move should span trought entire table. But If the probe is in midle of table I got soft limit error.
27 Feb 2010 16:08 #2093
by acemi
You can use G90 and an end position before the limit point.
27 Feb 2010 16:19 #2095
by eslavko
Where to read axis limit?!? And current position?!?
27 Feb 2010 18:19 #2097
by acemi
www.linuxcnc.org/docs/devel/html/gcode_m...38.2:-Straight-Probe
You can read the current position after the probing from #5061 ... #5069
You can get the probing result from #5070
The axis limits are in your INI file
27 Feb 2010 20:31 #2101
by eslavko
Here are misunderstanding I think...
I Know that axis limits are in INI. I wrote that. But how to read that value inside Gcode?
I know that #5061 to #5070 are probe variable.
But how to determine current position (before probe move?)
So let's go trought example.
I jog machine inside some hole. Now I want to find center of that hole.
1. Remember current coordinate (how to do that?)
2. Go slow Y+ from current position until probe hit or soft limit reached (remember position #5061.....)
3. Go rapid to coordinate from step 1 (back to start)
4. Go slow Y- (same as step 2)
5. calculate midpoint from step 2 and 4 and go rapid here
6. do same thing for X axis (this is precise)
7. repeat again for Y axis (now Y is precise too)
show message that's done and show diameter too...
Holecenter program's I found all require to tell hole diameter and position. I'm shure that's not necessary. Just don't know how to deal it.
Slavko.
Slavko.
- eFalegname
- Thank you received: 30
15 Apr 2014 20:03 - 15 Apr 2014 22:11 #45975
by eFalegname
Replied by eFalegname on topic Re:Axis Hangup!
I know, this is an old post, but...
1rst movement-
G38.3 Z0.001 and:
# 5061; #5062; #5063...become populated at the current position without error message, or: # 5420-5428 - current position including offsets (X Y Z A B C U V W).
1rst movement-
G38.3 Z0.001 and:
Last edit: 15 Apr 2014 22:11 by eFalegname.
Time to create page: 0.152 seconds
