Axis switch from mdi to manual mode and back
27 Nov 2013 19:59 #41194
by Rick G
Replied by Rick G on topic Axis switch from mdi to manual mode and back
Thanks for sharing.
Rick G
Rick G
16 Jan 2014 07:41 #42855
by kostas
Replied by kostas on topic Axis switch from mdi to manual mode and back
I want to connect some physical buttons for changing axis from manual to mdi, but can't connect to axisui.set-manual-mode pin when starting. The program terminates with the error "Pin 'axisui.set-manual-mode' does not exist"
I guess that axisui is not loaded yet at the time hal goes to connect the pin, so how does one use it?
16 Jan 2014 08:10 #42859
by dgarrett
Replied by dgarrett on topic Axis switch from mdi to manual mode and back
if you are using git master, the pin has been removed.
see:
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...6b15552825018b55726d
see:
16 Jan 2014 08:22 #42860
by kostas
I'm using the latest packaged version. The pin is there when I look from "halcmd show". But this is helpful info and actually I was looking for a way to interact with axis via axisui so that I could maybe find a way to also manipulate the axis jog speed with an encoder. I don't see any pins for that but I was thinking of looking at the python source and maybe add a pin or something. Do you happen to know if there are any changes for axis that could be used for this purpose?
16 Jan 2014 09:21 #42861
by dgarrett
if the pin axisui.set-manual-mode exists, then you can access it from a postgui hal file
specifed in the ini ([HAL]POSTGUI_HALFILE=filename.hal)
changing the axis gui slider value for jog speed would require modifying the axis gui but you may be able to use halui jog functions instead:
linuxcnc.org/docs/html/man/man1/halui.1.html
for example, halui plus/minus jogging uses pins:
halui.jog.n.minus,halui.jog.n.plus, halui.jog-speed (n = axis number)
16 Jan 2014 15:14 #42864
by kostas
I didn't think of the postgui file, thanks!
I already used the halui speed pins but the friend who needs this configuration would like to synchronize the axis jog speed slider on screen with the halui jog speed and also buttons that duplicate the keyboard arrows behaviour. I'm not sure this can be done without hard work though, so I may stick with just the halui pins for now.
17 Jan 2014 00:08 - 17 Jan 2014 00:24 #42878
by dgarrett
# Here is an example method to modify the axis ui behavior without
# modifying its python source:
# modify the ini file to include:
# [DISPLAY]USER_COMAND_FILE=mymods.py
# this new file mymods.py should be in the ini directory
# $ cat mymods.py
# in a postgui hal file, conect the new pin mycomp.max_speed
# as required
# $ cat mymods.py
print "*** Initial vars.max_speed:",vars.max_speed.get()
if hal_present:
mycomp = hal.component("mycomp")
mycomp.newpin("max_speed",hal.HAL_FLOAT,hal.HAL_IN)
print "*** Created pin mycomp.max_speed"
# this function is called at [DISPLAY]CYCLE_TIME interval
def user_live_update():
root_window.tk.call("update_jog_slider_vel",mycomp["max_speed"])
# as required
Last edit: 17 Jan 2014 00:24 by dgarrett. Reason: display indents properly using code
The following user(s) said Thank You: kostas
17 Jan 2014 15:35 #42907
by kostas
Nice! I made a quick test with halcmd and it updates the value. That's a good starting point, thanks!
20 Aug 2015 23:21 #61594
by ruffle
Replied by ruffle on topic Axis switch from mdi to manual mode and back
As I've just been tweaking my v2.7 config to add the MDI/Manual switcheroo functionality back in, I thought I'd update the thread for anyone else that wants to do the same.
Firstly, in 2.7 axis seems to nicely follow the MDI/Manual modes so my patch mentioned previously in this thread isn't needed, all you have to do is configure some hal stuff. Secondly I made use of the named thingies (toggle_mode.in instead of toggle.3.in) which makes it all more readable.
In your custom.hal file add
Then in custom_postgui.hal add:
Now pressing the MPG/Mode button on the HB04 pendant toggles between MDI(F5) and Manual(F3) in axis.
loadrt toggle names=toggle_mode
addf toggle_mode servo-thread
loadrt toggle2nist names=toggle2nist_mode
addf toggle2nist_mode servo-thread
net tog_mode xhc-hb04.button-mode => toggle_mode.in
net tog_mode_out toggle_mode.out => toggle2nist_mode.in
net is_mode_mdi halui.mode.is-mdi => toggle2nist_mode.is-on
net flip_to_mdi toggle2nist_mode.on => halui.mode.mdi
net flip_to_manual toggle2nist_mode.off => halui.mode.manual
The following user(s) said Thank You: eFalegname
- eFalegname
- Thank you received: 30
09 Oct 2015 02:28 #63585
by eFalegname
Replied by eFalegname on topic Axis switch from mdi to manual mode and back
I'm trying to do the same with the pendant Spindle button but I don't know why it doesn't work for me. Any idea?
Time to create page: 0.111 seconds
