Axis G10, coordinate system and program stop
29 Oct 2013 15:23 #40380
by Rick G
Axis G10, coordinate system and program stop was created by Rick G
The below sample file starts in G54 then switches to G55 to run a rectangle pattern.It works as expected.
However if you use the AXIS stop button while the rectangle is being run in G55 the dro and the display do not seem to follow correctly.
Start in G54 and touch off.
Run the program.
While the rectangle is being run hit the stop button.
Go to MDI and issue a G54 command.
The dro and the display continue to display as if G55 was still selected.
If you then enter
The display returns to normal.
Rick G
G54
G0 X0Y0
G0 X4Y2
G10 L20 P2 X0 Y0 (set X and Y cord)
G10 L2 P2 R45 (set rotation)
G55
G0 X0Y0
F50
G1 X3
G1 Y-1
G1 X0
G1 Y0
G54
Run the program.
G54
G0 x0y0
If you then enter
G55
G54
Rick G
30 Oct 2013 06:06 #40408
I am not sure if anyone here understands Axis, you might need to take this one to the mailing list.
Replied by andypugh on topic Axis G10, coordinate system and program stop
02 Nov 2013 18:00 #40506
by Rick G
Replied by Rick G on topic Axis G10, coordinate system and program stop
I actually posted this as an observation for others only. Toggling the coordinate systems brings everything back in sync and it seems to be a display issue only.
Rick G
Rick G
Time to create page: 0.356 seconds
