show only 2 decimal cases on DRO
12 Dec 2013 18:06 #41538
by jtc
show only 2 decimal cases on DRO was created by jtc
Hi.
My objective is that in the DRO it shows only 2 decimal cases, but I can't find on the documentation any way to do this.
Is this possible?
Thanks,
João Tiago
Is this possible?
Thanks,
João Tiago
12 Dec 2013 20:51 #41543
by BigJohnT
Replied by BigJohnT on topic show only 2 decimal cases on DRO
There is no setting for the precision of the DRO in Axis. You would have to modify the code to do that.
JT
JT
The following user(s) said Thank You: jtc
13 Dec 2013 06:09 #41568
You need to edit the file that creates the preview pane.
gksudo gedit (this opens gedit in super-user mode)
then open /usr/share/pyshared/rs274/glcanon.py
Edit line 1068 and change
format = "% 6s:% 9.3f"
to
format = "% 6s:% 9.6f"
for 6 digits of decimals/
Then save the file.
Replied by andypugh on topic show only 2 decimal cases on DRO
to
Then save the file.
Time to create page: 0.072 seconds
