Tool compensation
- allenwg2005
- Topic Author
- Thank you received: 4
23 Dec 2013 05:27 #41934
by allenwg2005
Tool compensation was created by allenwg2005
High folks,
OK, be kind I'm old and learning impaired!
I have some really stupid questions I'm having trouble resolving on my own, I'm sure this is very simple to all of you.
In looking through the manual I see two things (for the moment) I can't resolve when I return to Axis to try them.
1) I get the tool table, in fact it's seems like it's really handy.
But, When I hit touch off I'm supposed to see a choice for the tool table on the list, it's not there.
What have I done wrong?
2) I read that you can turn tool compensation on and off, I can't figure out how that's done.
Where is the switch for that?
Is there a simple way to set tool compensation that I'm missing?
23 Dec 2013 06:37 #41935
by emcPT
Replied by emcPT on topic Tool compensation
G43 loads the tool offsets (DRO will update for the current tool selected)
G41/G42 turns on/off the tool radius compensation. G40 turns it off.
If you call:
T1M6G43 it will update the DRO for the tool 1, with the offsets present on the tool table.
If you want to touch off with tool 1, I suppose you call it, touch the material then touch off. The other tools will "also know" your touch off, if the offsets are correct among all the tools.
If you call:
The following user(s) said Thank You: allenwg2005
24 Dec 2013 00:28 #41948
by BigJohnT
Replied by BigJohnT on topic Tool compensation
