tooledti becomes unavailable after use
- somenewguy
02 Jan 2014 02:36 - 02 Jan 2014 23:55 #42270
by somenewguy
tooledti becomes unavailable after use was created by somenewguy
So I am running 2.6.0dev on my laptop to sim and code, but 2.5 in the shop. . Once I run my code in 2.6.0dev, if i go to file > edit tool table, nothing launches. I have to restart axis to get it to work.
setup: ubuntu 12.04 32 bit
installed sim from git
using the ngcgui config with no edits aside from path to subs
if I launch axis, I can edit the tool table
i can turn on, home the machine, and select a tool.
after that I can still axis the tool table
ir I run a .ngc file (example attached below)
If I click on "edit tooltable" nothing pops open
I am going to go back to 2.5, but I wanted to document this so someone would be aware
EDIT: removed G40 complaints, should have own thread
Last edit: 02 Jan 2014 23:55 by somenewguy. Reason: two issues in one post is confusing, focus on tooltable
02 Jan 2014 20:53 #42280
Replied by andypugh on topic tooledti becomes unavailable after use
I have noticed this too.
There is a workaround, you can start tooledit from the command line.
I agree that it is a bug that ought to be fixed, though.
02 Jan 2014 22:57 #42289
by dgarrett
Replied by dgarrett on topic tooledti becomes unavailable after use
I cannot reproduce this problem on any of the machines available to me.
Please report your OS, how linuxcnc is installed, and the window manager in
use.
Here are some steps to try to isolate the
problem:
Start linuxcnc for the axis.ini (simulator) in a shell:
# If you are running a RIP, source scripts/rip-environment first:
$ source your_git_root/scripts/rip-environment
# run in background with trailing ampersand (&)
# (your path will be different):
$ linuxcnc your_git_root/configs/sim/axis/axis.ini &
# in the axis gui, duplicate the behavior where tooledit
# doesn't start when the axis gui menu item for:
# 'File/Edit tool table'
# is pressed.
# then, issue this command in the same terminal:
$ pgrep -l tooledit
# then, issue this command in the same terminal (that is -d' 'one blank in single quotes)
$ strace -f -e execve -p $(pgrep bin/axis|cut -d' ' -f 1)
# then press 'File/Edit tool table', verify misbehavior
# Ctrl-C to kill strace
$ pgrep -l tooledit
# post strace and pgrep results.
# example session (not-failing) is:
www.panix.com/~dgarrett/stuff/session.txt
use.
problem:
# is pressed.
$ pgrep -l tooledit
$ pgrep -l tooledit
- somenewguy
03 Jan 2014 00:38 #42293
by somenewguy
Replied by somenewguy on topic tooledti becomes unavailable after use
after dropping down to 2.5.3 I could not reproduce this error anymore. Andy are you wililng to do that for him? Gotta go shovel and get some work done. Otherwise I'll try and do this by the weekend. 2.6.0dev seems to be the issue.
Time to create page: 0.231 seconds
